My 40" Inch pizza oven in Florida
Re: My 40" Inch pizza oven in Florida
KB, it looks great, I think. I'm probably still missing something. From your drawing it looked to me like you were going to have a full 9" brick entry. From the pic , it looks like you will have a brick and a half entry (13.5") A brick and a half should be plenty of room to fit your flu in the center without offsetting (at least this much). It may help if you explain "4" of chimney wrap around flu"
If you can slide the vent forward off of (what I call natural fault lines) the better off you will be.
Just Sayin', 'cause, I'm probably missing something
Joe Watson " A year from now, you will wish that you had started today" My Build Album / My BuildComment
Look like the consensus is the offset is a weak point and needs redesigning.
My Original plan was a clay brick chimney surrounding the 18" x 9" clay flue with 1/2" air gap. I got scared about the total weight of the chimney and opted for plan B. Plan B using the clay flue wrapped in FB blanket surrounded with 2x4 steel stud and a Hardie board stucco finish. I feel I'm now stuck with plan B cause I did not extend any rebar out of the hearth to go into the brick's web to be filled with mortar as I went up on the corners.
With the addition of the heat break I did not perceive all the consequences and how much it would put the flue forward. The flue forward the additional two inches pushes the chimney face forward taking away from my limited counter space and increases the reach into the oven
, The idea of the offset looked good. Also I need to mention that increasing the reveal raised the overall structure of the outer arch to chimney transition and the throws my original concept drawing out of proportion. I flustered at this point.
Looks like total redesign of my concept.....bummer!1 PhotoComment
Sorry for the "bummer" KB,
I can't relate to all of your issues, but an 8" X 8" liner may be your only option. I had assumed from your previous posts that you were going to build an all brick chimney. Similar to what I did. That being 2" of brick liner surrounded by 2" of face brick with a 2" void packed with 10 to 1 Vcrete.
The weight of the liner can be placed on your arch. The weight of the face brick should be transferred to you hearth. The extra reach through the entry to your oven can't be avoided. But, that is also an extra reveal. Giving more flare.
A good thing about building the WFO is, it is a learning experience. Learning from your mistakes and others is part of the journey........... Thanks Laurentius for coming to my defense and teaching me something, although as the WFO apprentice here on the job. I deserve the abuse
But I can also dish it out
Swooning, I had to look that one up; I'm still wet behind the ears:
1.(dated) to faint, to lose consciousness
2.to be overwhelmed by emotion (especially infatuation)
Being flustered and confused most of the time is the norm for me, swooning has never occurred, in the end I always somehow figured it out.
Gulf,
I would like to build a all brick chimney but I don’t think that is a option at this point. I may be thinking wrong about needing to reinforce the corners of the chimney with rebar tied into the rebar and structure below.
I may have misled you on this post:
I really liked your idea of notching the bricks for the thermal break and the extra space of the vent area. I may be thinking wrong but, my thoughts are any grilling over coals would best be done in the vent area and not inside the oven.
I don’t think the 8x8 liner would help me much, but considering my options. I will going out of town the next two weeks and won’t have much time to work on the oven this weekend. So I will have plenty of time to consider all my options…….. Looking for suggestions and or comments. Thanks in advance.Last edited by kbartman; 07-04-2013, 02:46 AM.Comment
KB,
Gulf,
I would like to build a all brick chimney but I don?t think that is a option at this point. I may be thinking wrong about needing to reinforce the corners of the chimney with rebar tied into the rebar and structure below.
I really liked the idea of notching the bricks for the thermal break and the extra space of the vent area. I may be thinking wrong but, my thoughts are any grilling over coals would best be done in the vent area and not inside the oven.
I don?t think the 8x8 liner would help me much, but considering my options. I will going out of town the next two weeks and won?t have much time to work on the oven this weekend. So I will have plenty of time to consider all my options??.. Looking for suggestions and or comments. Thanks in advance.
I sincerely hope that the rebar isn't necessary for a brick chimney. I wouldn't think so, given the relatively short height that they need to be for an oven to draw. They have a fairly large footprint where they sit on the structural hearth. If one is being built high enough to extend through a structure then the structure is used for lateral bracing.
By the time that I was capping my chimney, I had came across a couple of sections of 8" double walled SS flu and the cap/spark arrestor. Had I of found this earlier, I am sure that I would have taken a different route.
Not knowing how my oven would draw at the chimney's present height, I left my self an option for using the SS to extend the chimney. If I were to have extended the chimney, I wanted it to have the same look. (The option won't be necessary though, my oven draws fine.)
I would have removed the top bricks and have inserted a the inner section of the pipe into the SS collar. I would have continued with the 2" face brick and poured vcrete in the void.
I'm not reccommending building brick chimneys for use as flus on WFOs. It is just what I did. If I were to reccomend a flu, it would be factory built double or triple wall SS pipe, anchorplate, and spark arrestor. They look a heck of a lot easier to me
Some times it is good to step back from any large project and take a breather to weigh out the options. I'm looking forward to watching your progress.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My BuildComment
No, you don't need rebar in a chimney especially on corners....that is the strongest part of masonry structures, and without being encapsulated in concrete, rebar running up the corners will do nothing structurally.
Correct. For example, just look at some of those huge furnace chimneys or ones that stand in place after a home has burned or crumbled around it.... No bracing, used.Old World Stone & Garden
John RuskinComment
I'm back from vacation, ready to make some progress and move forward. I will be ordering materials for the thermal break soon: Ceramic rope and sealant. I plan on having a 1/2" horizontal and a 1/4" vertical thermal break gap. I plan to use 1/2" and 3/4" rope in these gaps and fill the 1/4" gap with the sealant inside the smoke chamber/chimney. I think the below mentioned materials will work and the price is reasonable............ Any thoughts or suggestions is appreciated.
Ceramic rope
SealantComment
KB,
I am sorry about not replying to this question sooner. I've had a lot going on on the "home front". If I understand correctly, I think that you are describing a thermal break similar to what I did. (Page 10/post 93, and Page 11/posts 102 thru 106)
I used the Rutland Black to seal both the inside and back side of the thermal break. I later, cleaned as much of the sealer from the inside as I could. To me it looked like crap. Since then, I have seen others who have found other "caulks/putties" that had better food safe remarks in their product descriptions. I think that Russell (UtahBehiver) And Dennis (Deejayoh) both found more suitable materials for sealing the inside gasket. Maybe they or someone else will chime in on this thread.
I hope this helps to get you an answer
Just went back and was reading everyone's posts on my thread. I appreciate everyone's help thus far. I could not have made it this far without your input and all the great info and pictures found on this forum. Thanks a million!!!!
I haven't made much progress since returning from vacation the rains and my indecisiveness on my chimney\vent are hindering me and have brought me to a stand still
..............I was hoping of coming up with a plan by now..........Thanks Stonecutter, You are right, I don't remember any rebar in any old chimney that I've seen.....That gives me a better perspective on building a brick chimney
I trying to figure out how I would support the back side of the chimney over the dome that will be covered with 4" inches of insulation. I'm wondering if I could span this area with metal support of some kind and how I could fasten the bricks to this support?
Thanks again for everyone's help.Comment
Thanks Gulf, I Just read your last post after submitting my last post. I'm very slow at composing these posts as you can see by the posted time between your and mine. Thanks again.
Ps.
What you all think about this for my floor thermal break? GraingerLast edited by kbartman; 07-25-2013, 03:04 PM.Comment
I think it would work. I have seen where others have used similar. Look back again though, if you will to my other post. The link for page 10/post 93 in it shows how I did my floor break. I used 2 runs of a 3/4" flat gasket material. That left about 1/4" of space at the top that I have let fill in with ash that hopefully separates the fibers from the floor surface............................What you all think about this for my floor thermal break? GraingerJoe Watson " A year from now, you will wish that you had started today" My Build Album / My BuildComment
.....will have a thermal break and chimney modeled after the Mississippi Queen….. Need all the help I can get………
