Well I was hoping to get her dried in. Oh well, at least I think I'm finished with the curing. Dome top read over range on my IR thermometer with top thermocouple reading in the 950F range. I poured the coals to her at the end of the evening. Today dome holding steady 650F saturated temp, fire out..
My 40" Inch pizza oven in Florida
Re: My 40" Inch pizza oven in Florida
4 PhotosLast edited by kbartman; 10-16-2013, 10:47 AM.
Originally posted by kbartman View PostBeen looking for a picture of the Pixar's scared guy, please post pic........
1 Photo
Thanks Guys,
More screws for the felt, I'm running out of places to put them I figure a washer would help. I hope I will still have room for screws on the metal lath..........I found my first heat induce crack today. I should have started with charcoal. The kindling fire for the bed of coals was very hot quickly. I thought it could handle it
. The crack is maybe 1/32" or more. I tried to photograph, it did not show up. Oh well it's official all domes crack at least mine. I'm sure there are many more under the insulation
. The oven is starting to clear now, crack is smaller maybe 1/64". It is on the inner arch. Should have started with charcoal.
I was able to finish the insulating and get the trusses mostly complete today. Completed thermowell for enclosure temp... I have 5" inches of fiber blanket surrounding the upper portion of the dome 3" the lower. I used the rest of my vermiculite at the bottom of wall enclosure then finished with fiberfrax loose insulation up past the additional 2'' of blanket on the upper portion....Hopefully get the roof dried in tomorrow.3 PhotosLast edited by kbartman; 10-14-2013, 08:32 PM.
Originally posted by kbartman View PostBeen looking for a picture of the Pixar's scared guy, please post pic........ I hope it will blend nicely when the stucco and lights are complete
kbart
Gonna have to use screws to attach to hardiboard. If you are worried about moisture at the penetration, smear some silicone on there. But the pressure of the screw should prevent moisture. Great job BTW.
Texman
Originally posted by brickie in oz View PostYou have to change the way things look, pic 3 reminds me of a Pixar movie scared guy....Originally posted by Laurentius View PostJust imagine a roaring fire in its mouth, with the circles glowing day-glow green in the dark?....... I hope it will blend nicely when the stucco and lights are complete
I had some dome clearing on the last fire. So far I have not seen any cracks. The last firing on Sunday the oven held heat all week 150F on Friday. I think I'm ready to pour the heat to her.
I installed a couple more thermowells on the opposite side of the others. I think I will add one more over the oven to monitor enclosure temp.
I hope to get the roof trusses done, finish insulating, and get the oven dried in this week. I have the next couple days off work.
I trying to get my mind around attaching the felt paper to the Hardieboard. I tried a hand stapling gun and 1/4" staples the shortest I could find. No luck just bent staples.... I was thinking a hammer type stapler may do the trick, or would it bend the staples also? Any suggestion before I spend the money for one?
3 PhotosLast edited by kbartman; 10-13-2013, 03:24 PM.
Nice job, now the fun begins.
Oks Guys,
As tropical Storm Karen fizzled out in the Gulf Of Mexico, I was able to finish the outer decorative arch and continue on the curing process. I was shooting for the old rugged antique look, nothing fancy. I thought tapering the bricks would take away from that. I hope it will blend nicely with the existing stucco walls.
I'm Glad I took the time to incorporate the heat break like those whom have trodden before. The oven was still 575F this morning with minimal insulation and only a cement board door. With the dome nearing 800 F last night, the decorative arch was only slightly above ambient.I give credit to all those on this forum, Thanks
5 PhotosLast edited by kbartman; 10-06-2013, 12:27 PM.
Originally posted by david s View PostWe live in the tropics and during the wet season the humidity is so high that mould on clothing in wardrobes is sometimes a problem. Porous refractory gets pretty wet even without any direct rain and the oven interior is also sometimes mouldy. Both the chimney cap and door are much bigger in area than a vent, so would expect more uptake of moisture through them than a small covered vent. The chimney cap can allow some moisture through and after heavy downpours with some sideways rain the tell tale sign of some soot on the floor bricks under the flue is evidence. Likewise driving rain around the entry will find some water ingress. The vent does a good job of removing the water and I've done it at least once every wet season for the past four years without creating any oven damage, so for us a vent is mandatory.Likewise a hole in the supporting slab to communicate with the underfloor insulation.
Sorry, should have added that our oven is an igloo style and exposed to the weather.Last edited by david s; 10-06-2013, 01:49 AM.
The joys of living on the high bank.
those once in 100year floods are nothing to worry about
