Scratch coat
  • Scratch coat
    I have just insulated my oven with 4 inches of ceramic fibre, what should I use for a scratch coat for my stucco finished dome.
    Re: Scratch coat
    regular old mortar . s-type from the big box hardware store.
    My build progress
    My WFO Journal on Facebook
      Re: Scratch coat
      I agree with the first reply. You can look at the link of my build below. The plaster (what you call mortar) worked out perfectly. I suppose your oven will not sit out in the open, but will be covered.
      Best of luck.
      sigpic
      Check out the link to my build and pictures here
        Re: Scratch coat
        Thank you for the replies. Yes my oven will be under cover.
          Re: Scratch coat
          How will you finish the final enclosure. I used scratch/brown coat stucco with acrylic additive to increase the water resistance. I will not have a cover so the final shell needs to be water tight
