Howdy folks, looking to make an inner insulated door, I do not have enough cal sil board left over to sandwhich, would rather not buy another expensive piece for a door, wondering what options I have for materials for insulating inner door. Thanks, pat
Tags: None
Re: Over Door Insulation
Some have used vermicrete, vermiculite and concrete, with stainless steel or steel on the interior side of the door. You should be able to search on doors and pull up several. Others have used a hollow metal door structure with ceramic insulating blankets stuffed in the hollow.
The one big no-no is galvanized on the inside. The zinc will vaporize in high heat and these vapors are poisonous!!
Chris
This is the one I am making. I intend to stuff the cavity with ceramic fibre and then dress it up with timber on the outside. I scoured the threads and found a lot of different ideas but I am hoping that this will work.
The thing is ready to put together now and the last thing is a strip of metal that fits under the tabs on the top of the inner section and riveted in place after the insulation goes in.
Hope this is of use.
Regards...........Steve
3 PhotosCheers ......... Steve
Steve thats a clean door. NiceMatthew 19:26. With God all things are possible.
Steve,Originally posted by Greenman View PostThis is the one I am making. I intend to stuff the cavity with ceramic fibre and then dress it up with timber on the outside. I scoured the threads and found a lot of different ideas but I am hoping that this will work.
Very nice looking door.
Mount your handles on the outer skin before putting the sandwich together, that way you will transfer less heat to the outside thru the handles. My outer wood skin on the door has actually chared next to thr handles and they go thru to the interior of the oven. You may also want to cut away some of the contact points to the inside panel to reduce some of the heat transfer.
Chip1 PhotoLast edited by mrchipster; 04-16-2013, 08:03 AM.Chip
Thanks for the encouraging feedback folks.
And thanks for the tip about attaching the handles Chip.
I was going to use some hardwood on the outside of the door. We have some here that handle heat better than most (yellow stringy bark and tallowwood). Good point about the contact points as well, I will make some modifications.
Soon be smelling something good coming out of this fiery beast!
Cheers...........SteveCheers ......... Steve
Kevin - I used aluminium for the whole thing, rivets included. Found some good offcuts at the scrap metal yard and the whole thing came to less than $20 up to here.
Need to go back and grab some for a peel and some ash handling gear.
Cheers.........Steve
The piece facing the oven is 14 g or 1.8mm and the rest a little lighter. The angle s 1.5. Due to the source I can not be 100% sure of those sizes but they are as near as damn is to swearing.Cheers ......... Steve
Thanks for the feed back folks appreciate it
