Expansion gap between cooking floor and dome
  • blaise
    • Mar 2013
    • 4
    Hi there !
    Could anybody tell me what would be the "ideal" gap between the cooking floor and the wall of the dome in a 36" wfo considering, of course, that the dome is outside the cooking floor.
    I'll use 32% firebricks.
    Any advice is welcome !
  • blaise
    • Mar 2013
    • 4
    Re: Expansion gap between cooking floor and dome
    Seriously, no reply ?
    Have you all, guys, built your oven(s) with the dome on the cooking floor ? Didn't any of you built it with the floor inside the dome ?
    • brickie in oz
      • Mar 2009
      • 3445
      Give them a chance to wake up and shower before they reply.....
      I built my oven on the floor, why wouldnt you?
      My Build.
      Books.
      • blaise
        • Mar 2013
        • 4
        Well, in the Pompeii Oven Instructions they say that the majority of Italian ovens are built with the floor inside the dome and the main advantage is that it offers better thermal performance.
        • brickie in oz
          • Mar 2009
          • 3445
          I cant see how the thermal performance can differ from either type of build.
          You have to remember that the "plans" are just a guide and a starting point.
          My Build.
          Books.
            About 5mm should be plenty. Some builders have used corrugated cardboard which will burn away when you fire the oven.
            • Tscarborough
              • Oct 2009
              • 3341
              It is not properly called an expansion joint nor is one needed. The dome will expand more than the floor due to the greater length involved. It is a construction joint and can be made as tight as you want. I prefer to build on the floor though.
              • blaise
                • Mar 2013
                • 4
                Many thanks for your replies.
                I think I'll build on the floor
                • stonecutter
                  • Jun 2007
                  • 2003
                  Either way, neither way helps an oven perform any better. Good luck with your build
                  Old World Stone & Garden
                  John Ruskin
