32 Inch Pompeii in Northern California
  • boerwarrior
    • Apr 2013
    • 454
    Like some others on this forum:
    1) I knew absolutely nothing about pizza ovens a few months ago
    2) I started out building a Vault type oven (based on a foam form) after I saw it at a building supplies store
    3) I decided to change my design part way though building the base and had to make some significant modifications
    4) I wish I had discovered this forum sooner!
    I am now building a 32? Pompeii oven.
    The base is almost complete ? pictures to follow. I originally started with a 36? wide base to accommodate the vault oven but I have now widened it to 53? ? which according to my calculations should accommodate a 32? oven plus 2? insulation plus an outer brick wall. (32+9+4+8=53) I know that 2? of insulation is barely enough ? so I will do 2? at the bottom but more than that as I get progressively higher.
    I also had a front to back problem with the base size ? I originally only made it 50". I plan to address this in two ways:
    1) I added 8? to the back of the base
    2) I will make the front arch (in front of the chimney) flush with the front of the oven. That only gives me a tiny landing I know, but I have surface space on either side of the oven to ?stage? my pizzas.
    The interior height of the oven will be 16?. I am planning to make the front opening 10? x 16? with a slight arch.
    My first forum question is:
    For a 32" Pompeii, what size do you recommend I make my chimney opening? I have read many threads on this topic and can?t seem to find a consensus. I need to decide this soon as it determines the placement of my oven on the base.
    Thanks!
    Neil
    Re: 32 Inch Pompeii in Northern California
    6" in diam or the equivalent area in cross section if it's square or rectangular. You could go bigger, but don't go smaller.
    • boerwarrior
      • Apr 2013
      • 454
      Thanks David!
      I will probably use a double walled flue because I need some height to get the smoke out of the garden - so I will plan on a rectangular to circular transition and ensure that the rectangular opening is larger in cross section
      • boerwarrior
        • Apr 2013
        • 454
        Here is a picture of my base so far. I can attach picture of the build to get to this point but I did nothing special that has not been done by all the other oven builders on this site!
        As I said, I modifed the design to accomodate a 32" Pompeii (originally was going to build a Barrel/Vault)
        Next step is to pour a bit of leveling compound on the slightly rough concrete surface, then put down 3" of CalSil Board, then start building the oven!
        • boerwarrior
          • Apr 2013
          • 454
          In order to check the measurements I cut a piece of OSB the size of the interior of the oven and you can see it's going to be a tight fit. I will however be able to get 2" of insulation around the oven at the bottom. I will use thermal blanket.
          The surface wasn't completely level so I poured a thin layer of cement-based leveling compound on it. Probably overkill but I would rather start as level as possible.
          • Cheesesteak
            • Mar 2011
            • 192
            I love the stand - looks fantastic.
            • boerwarrior
              • Apr 2013
              • 454
              Thanks Cheesesteak
              wow, I just looked at your outdoor kitchen pictures - incredible! I hope mine is 1/10 as nice when I'm done!
              Neil
                • 5260
                Nice looking base sure your build will follow suit.
                • boerwarrior
                  • Apr 2013
                  • 454
                  Thanks UtahBeeHiver!
                  today I cut the floor bricks. Not nearly as accurate as many others on this forum but I think they will work. What gives me comfort are the numerous comments along the lines of "ash fills in the gaps" !
                  I haven't yet decided what I am going to do for the very front 5 inches. I may extend the firebrick all the way to the front or I might use the antique bricks for a narrow front landing. I will decide that later (but soon!)
                  Neil
                  • boerwarrior
                    • Apr 2013
                    • 454
                    QUESTION: About Thermocouples...
                    I have a fancy voltmeter that can read temperature from "K" thermocouples so I bought a couple of inexpensive high temperature (rated to 1800 degrees) thermocouples online. I tested them in my AGA oven and they seem to work great.
                    I'd like to place them in the firebrick so I can read the temperatures - especially in the beginning when I am learning how to use the oven and while the oven is still drying out.. Any suggestions where to place them?
                    I found a couple of references in the forum and it seems like placing one in the center floor brick (about 1 1/2 inches in from the bottom) and one in one of the bricks near the back of the dome would be good? Does this sound right?
                    Thanks! Neil
                      • 5260
                      Depends on what you want to measure. I only put in two and I talked to Karangi Dude (he put in a number of TCs) and based on what I wanted to measure (brick saturation). I would look at his build because he has alot to temperature data. Here is where I placed mine base on recommendations from KD.
                      http://www.fornobravo.com/forum/8/wo...tml#post133700
                      • boerwarrior
                        • Apr 2013
                        • 454
                        After waiting a week for it to dry (it was a thin layer) I sealed the leveled surface with concrete sealer.
                        Next step is to place the Calcium Silicate Board (thanks gswarriors!) on top and lay the floor. I will lay the floor bricks on a thin, dry fireclay/sand mix.
                        QUESTION: I have heard that builders have issues with mortaring the soldier bricks to the CalSil Board because the board is so absorbent. I have seen a suggestion in this forum to "butter" (literally use butter or margarine) the board to prevent the CalSil soaking the water out of the mortar. What if I were to spray some high temperature (1200 degrees) paint on the edge (outer 5 inches only) of the board to slightly waterproof it before laying the solders? Anyone see any issues with this?
                        Neil
                        • boerwarrior
                          • Apr 2013
                          • 454
                          one of my concerns would be paint fumes but this thread seem to address that:
                          http://www.fornobravo.com/forum/f9/o...umes-6213.html
                          I think I am going to try it....
                          Neil
                          • Cheesesteak
                            • Mar 2011
                            • 192
                            Neil
                            I wouldn't mortar anything to the insulation board.
                            • boerwarrior
                              • Apr 2013
                              • 454
                              Really? So I should just mortar the soldiers together but not put any mortar underneath?
