Re: 42 inch Michigan Oven
Nice job, getting close to plug time. Take some pics of your jig and post so future WFOers can see.
Originally posted by Bert View PostJohn
All I can say is WOW!
It must have taken much time to prepare the dome for the mock up...but it seems that what you lost at preparation stage you gained with the actual build.
Very interesting and effective approach.
All the best
Bert
It absolutely took a lot of time but I learned a lot in the process. The learning was probably the biggest advantage and if I were to do another, I wouldn't mock it up. But it helped me understand the process long before actually applying any mortar. The biggest thing was my self-imposed deadline and knowing that without a lot of prep work during the long winter, there would be no way to get it done in time. Heck, it snowed a little here on May 11th!
Originally posted by boerwarrior View PostThat looks great John!
That's a heck of a lot of brick cutting!! But I'm sure it will pay off!
John
Would love to see some pictures of inside the dome and your arch preparation.
Keep it up! Look forward to watching this build through to completion.
All the best
Bert
Couple of photos of this weekend's progress. Finished courses 11 and 12. At least the courses are getting small enough to fit in the frame now.
I didn't get time to get pics last evening as a thunderstorm was moving in as I rushed to get the last few bricks in and I had to button things up rather quickly.
Take a look at the attached not very attractive brickwork. The temperature of the bricks you can see is close to 1,000 degrees Fahrenheit - and there are almost no cracks (as seen from the outside) that follow the vertical alignments.
Neil
And, you have fire!
Originally posted by jbruning View PostThanks Neil. I am finding, however, that it is getting more difficult to keep the vertical joints from aligning. The upper courses are requiring more frequent 'adjustment' bricks to keep on bond. Most of my oven was cut during the winter months and assembled dry inside so I could maximize my spring build time. But as I was doing so, I realized that some cuts would have to be made as I constructed. This became more evident in the higher courses so I made a few extra 'blanks' for each course to provide a starting point for my adjusting bricks. So far, the pre-build IMHO, has saved me a lot of time during assembly, AND it allowed me to think through some of the more complex geometry issues early on so as to not get bogged down too much now.
Neil
Originally posted by boylanta View PostJohn,
Looks great.
Nice progress.
It's pretty satisfying to get a complete chain above the inner arch, isn't it?
Originally posted by boerwarrior View Postlooks great! nice job avoiding vertical seams!
John,
Looks great.
Nice progress.
You'll be lighting curing fires before you know it!
