Re: 42 inch Pompeii build i Norway
My blade would spark after a few cuts. When I cut in to the concrete something like molten metal or slag (red hot, not sparks) rolled off the blade, not much but I think enough to expose fresh diamond. Then it was like new again.
Wetting the bricks helped a lot too.... it helped keep the blade sharper for longer periods.
It doesn't take long to soak a brick, about a minute and its almost soaked through to its core.
I've never seen this mentioned on the forum but it could be, people are discarding their blades a little too early? I know my first thought was "Get a new blade"
I took the middle ground and wet them a bit to stop the bricks sucking the moisture straight out of the mortar.
