Re: Zeke's 40" in Modesto
Good tip Aceves - I'll give it a try. I already have quite a bit of sediment in the bucket after draining the pan a couple of times.
Zeke,
Another tip: once you are done cutting your firebricks for the day, do not throw away the wet firebrick powder clay at the bottom of the wet saw basket. Just dump most of the water out and let the firebrick powder clay dry overnight. You can then use this firebrick powder clay in your homebrew mix for the next firebrick course.
Might as well use this clay as it will have the same refractory properties as the firebrick you are installing. I personally used 3 sand, 1 portland, 1 lime, 0.5 bag fireclay and 0.5 leftover firebrick clay, by volume. It worked great, and I didn't waste firebrick clay after a day's cuttings.
AcevesLast edited by aceves; 06-19-2013, 04:54 PM.
Aceves - I'm using the homebrew and for now pretty closely sticking (no pun intended) to 3:1:1:1 recipe. I do have some stray clumped pieces of sand/fireclay that I used to level and secure the oven floor. If my mix is a little wet I'll crumble a bit into the mortar to firm it up a bit. I'm still learning to work with. Your enclosure roof is great.
John,
I VERY much appreciate getting your insight early on. I can still cut access holes and will do so!
Cheers!
Hi Zeke,
Looking good!
FWIW, I used an arch form with a solid face like you have. Although yours is shimmed up much higher than mine, I had a bit of difficulty removing the form when goobers of mortar oozed into the inner space. So you might consider making sure they are knocked off inside as you go up, or create an access hole in the middle of the form. Just an idea. It took me about 15 minutes to remove the form. Thankfully this was just minutes after laying the last several top bricks and that mortar was fresh, but the few little bits (like 1/8") near the bottom were buggers. Of course, I had to be fairly gentle and couldn't bang it around too hard to make sure I didn't break the bond on the freshly laid bricks.
Thanks Zeke!
I look forward to seeing your build progress. Keep at it, it's going to be a fun journey!
As for your concerns about the cracks, do not worry, everybody gets cracks in their dome. It's inevitable. Once you start firing, you will see more of them. Just cover them up with a patch of mortar and keep going. Are you using a special mortar or the homebrew? Just curious. And go with your idea of cutting the subsequent arch bricks to go back into round. The performance of your oven will not be affected by the minor setback of these few bricks. And since it is so close to the arch, nobody will see this minor variation when they look in the oven. Just make sure you get a good bond with the mortar and keep moving up the courses.
AcevesLast edited by aceves; 06-19-2013, 10:45 AM.
Okay, finally some real progress to report...
I completed the second course, in which I've started "tipping" the bricks to create the vertical curve of the dome. A couple of questions though.
I've noticed a few small mortar cracks on the exterior surface of the dome. Is this cause for concern? I'm wetting bricks before placing them and as I go, am using a spray bottle to wet bricks that have already set.
I laid the base and first course by eyeball method and started using an IT for the second course. When I reached the arch at the end of the second course I saw to my dismay that I am not round here - see fifth and sixth pics with IT. Rather than dismantle and reset, my thought is to begin cutting the back of subsequent arch bricks (interior surface of dome) to bring this spot back into round. Thoughts?6 Photos
Aceves, yours is one of the builds I've studied carefully. You're finish details are great!
Hi Zeke,
Glad to see a fellow NorCal builder starting out! Keep us posted and include pics. And to get the best use of this forum, post your questions (about anything) during the building process and we will try to help out as best we can. Good luck!
Aceves
Alright, thanks for the thoughts gents. Neil, that makes sense about the cold air coming in through the opening. I'm going to live with it as it is an forge ahead!
Zeke,
like you I have about a 1/4 inch expansion gap between my floor bricks and my half-height soldier course. While it is hard to see when the interior temperature is close to 1,000 degrees, my floor doesn't seem to expand a huge amount. Like Utahbeehiver said, the gaps fill with ash anyway! With respect to your other gap near the arch - in my oven it doesn't get incredibly hot at that place on the floor so leaving a gap there is probably not as important. (maybe gets to 400 degree there at a guess? I didn't measure - just guessing)
Remember when you are firing the cold air is coming in at floor level so that probably keeps things a little cooler down there.
My bigger issues are higher up on the inner arch where is does get incredibly hot - I have some cracks up there which I needed to fill.
Hope this helps
Neil
Originally posted by zekebv View PostAny thoughts on my last question? Thanks.
Chip
Here's my first picture and it comes with a question. Is it advisable to leave an expansion gap between the oven floor and both inner sides of the entry arch base brick?
In the picture, the arrow pointing right shows the expansion gap that runs along the circumference of the oven floor and the other arrow points to the inner side of the entry arch, which is where I'm wondering about the expansion gap.1 Photo
Thanks Beehiver - this is definitely a learning process. I've got some pictures and hope to post them. I've admired your build.
