I now started to cut my bricks for the floor after 2 days of debating on putting the floor on top or inside I've decided to cut for a inteior placement. I borrowed a friends dewalt 14" chop saw it did work well curious to see if anyone else used it before a few more hard cuts left. Question there are a few small corner pieces about 1/2 triangle size on the floor that i have not cut pieces for can i fill these with the brick dust or just use the home brew mix?
Would there be an issue if I did not trim the ceramic board? can I just leave it extending from the exteior dome wall? Is there a purpose to trim or not to trim
