Do I need to put insulation on the outer arch/entrance outside the dome?
I'm deciding between a brick arch or a straight entrance that I could make with concrete on the top, in which case I'd want the concrete slab exposed for the look. I would think that since I'll have an insulated thermal break between the dome and entry, that I don't need insulation around the entry.
