insulation on entry?
  • jimkramer
    • Jun 2009
    • 143
    Do I need to put insulation on the outer arch/entrance outside the dome?
    I'm deciding between a brick arch or a straight entrance that I could make with concrete on the top, in which case I'd want the concrete slab exposed for the look. I would think that since I'll have an insulated thermal break between the dome and entry, that I don't need insulation around the entry.
    Here's mine:
    http://www.fornobravo.com/forum/f8/j...man-15992.html
  • Les
    • Sep 2005
    • 2945
    Re: insulation on entry?
    It's not required. You are pretty much giving up the heat at that point anyway.
    • CoyoteVB
      • Oct 2012
      • 66
      I am a amateur but I do not see the value. The heat will be held in the dome. Once the heat leaves the dome via the door and chimney is to gone.
      • stonecutter
        • Jun 2007
        • 2003
        If you frame your enclosure with wood, then it would be a good idea. Otherwise x3 with what has been said.
        Old World Stone & Garden
        John Ruskin
