Re: Cyungle's 39'' Pompeii in Queen Creek, Arizona
Looking good! Interested to follow the oven being finished. Congratulations.
It has been a while since updating and I've made a lot of progress. The four images summarize the major accomplishments.
Once I got the radius tool rebuilt to center the rod on the brick rather than on top of it, all of the dome bricks lined up perfectly. I cut up lots of wedges to slide in the gaps to minimize the amount of mortar needed.
The trickiest part of the dome was working the dome into the arch. It required a lot of work from the brick saw but it turned out just fine.
Just like everyone has recommended, the exercise ball was the perfect solution to completing the top.
After completing the dome, I scooted the arch form up to complete the outer arch. I ended up squaring the top of the arch to prepare for the chimney.4 Photos
This one sharp looking build so far. I really wish I had done my base similar to how you have. Get cracking while the weather is cool. I can tell you it was brutal doing the majority of my build in the heat of the Phoenix summer.
After two months of 100F+ days and monsoon humidity, the temperature has finally dropped below 100F and it's finally tolerable again to work outside. The hearth is 7 inches of reinforced concrete and a 3-inch void in the middle for the insulated vermiculite/cement mix. The slump for the concrete was a little chunky around the edges so I thinned the mix for the remainder to minimize voids.
The most surprising thing that I found during pouring of the insulated concrete phase was that the calculated volume of the void was about 3 cubic feet but it ended up requiring 6 cubic feet of vermiculite to complete the job. I could only conclude that if vermiculite is used for making insulated concrete, it compresses so you have to double the amount of vermiculite per calculated volume.
After a little over a week, the insulated concrete is firm enough to build on so hearth construction begins. The firebricks are laid out in a herringbone pattern over a very thin layer of fireclay and water mixture.4 Photos
Your build is really shaping up. I like your stand design
Artistically Disguised Utility Boxes - A Waymarking.com Category
Try this where I live artist are allowed to paint utility boxes to disguise them I hope the link works
Originally posted by Cyungle View PostI haven't quite decided what the finished product is going to look like. I like the stucco and tile work that I've seen others do but I have never done stucco or tile so I may have to experiment first. I know that I want to do something that I haven't seen done. I have a friend who is really good at gang tagging with spray paint (you may have seen some of his work on the sides of boxcars) and he volunteered his services but I don't want my WFO looking like an east LA liquor store. Still a few weeks of building before I decide.
Next phase is complete! The forms for the hearth were a pain to build but I didn't want to risk any mishaps that would ruin the hearth slab.
For the base, I fabricated a frame that is supported by a column in the center and anchored in slots cut into the edges of the block wall. I've seen a lot of folks do the same with wood but I'm a better welder than carpenter and didn't want to risk leaving anything combustible that I would regret later. The floor substrate is just sheets of concrete board. I also welded in some 1/2 inch rebar that sticks up through holes in the Durock. I'm not worried about rust .. this is Arizona; nothing rusts. That's why the Defense Department parked all the decommissioned places in Tucson after WW2.
For the front radius, I built a rounded form with a couple of sheets of lexan attached.4 Photos
It looks good so far. We also have the scorpion/bug problem, so I built the wood storage space as a separate compartment from the underside of the oven.
Originally posted by Cyungle View PostI'm kind of making this up as I go along. Not the best way to plan something that isn't easy to change but I like the spontaneity.
Interesting way to span your base opening...I like the brickwork. Are you doing any kind of finish over the CMU or are you leaving it as is?
Nice job. I like it.
About the size of the cavity under the hearth; I was concerned at first that it would be too small but I also thought about doing away with it completely. In Arizona, a woodpile is just a place for scorpions to hide. In the end, I settled with the narrower space and have already designed a fancy cradle that I'll fabricate later on that will fit in the cavity.
The next phase of construction is illustrated in the attached photos. The first photo is the disastrous result of a surprised dust storm that tore my shade canopy out of its footings and carried it across the yard.
In the others, I mortared in the block wall and fabricated a bridge over the cavity opening. I wanted to do something that I haven't ever seen done.4 Photos
Originally posted by UtahBeehiver View PostCY,
Maybe it is an optical illusion deal, would hate to have you lose all the space underneath. Looks like 3.5 CMUs on each side of entry, can you take out the 1/2 CMU on each side? It will give you more entry way space. Good luck.. I haven't finished my tool storage drawer yet, but that is what I will have in that space.
CY,
Welcome to the forum. I imagine it is hot in AZ. We are in the triple digits here in Ut so I suspect you are even hotter. Nice start, one comment, fairly small entry/access to your storage under the hearth. Maybe it is an optical illusion deal, would hate to have you lose all the space underneath. Looks like 3.5 CMUs on each side of entry, can you take out the 1/2 CMU on each side? It will give you more entry way space. Good luck.
