I've been lurking for a long while and I've finally got time to do my own oven project. The FB plans and peoples' build threads have been invaluable during my own planning.
The plan is for a 30", no-vermicrete oven, which will be finished with a brick outer-igloo. Several years ago I built a clay/sand oven which was compromised from the start by the habitual dampness of the scottish weather, so with this build I'm trying to avoid things which the weather might complicate.
I finished the plinth nearly two months ago. Available space in our garden was an issue, which is the reason why the oven will be so small compared to some of the behemoths on here, but 30" will be plenty big enough for our use of small pizza-parties, bread, and roasts.
A tree (fatally damaged in a storm) and the old oven used to inhabit the space where the plinth is. The tree needed to come out eventually so we took the opportunity to take its roots out too and then turn the resulting hole into the foundations.
, so I had to use some treated timber.
