On my 5th course I decided to try making cuts on the side of the brick. I figured they'd be less likely to fall out than a straight cut. I made four bricks with 5 degree side cuts, placed them side by side dry, they looked good, so I cut the whole course that way. Turns out they don't really fit right - big gap on the inside of the oven (1/4-/12" in a few places), whereas the straight bricks fit nice and tight on the inside.
Will the side-cut bricks actually stay in longer? I don't care about aesthetics of tight fitting bricks. It's taking me MUCH longer to cut and place them, not sure if it's worth it. I could experiment to get the angle right, maybe a 4 degree (as the gap on the inside has been wider than the outside with 5 degree cuts).
Only problem is I'm doing most of this at night, can run the saw too much or the kids will wake up, and the neighbors will hate me.
