not sure that last posting posted -- I am attempting to calculate how much Portland cement and vermiculite I need to purchase. I have a 6 ft by 7 ft with a 4 inch depth. Need a 5 10 1 ratio -- any help?
vermicrete
Re: vermicrete
Hman
That sounds like 14 cf to me of vermiculite. Get some extra, maybe one or two cf if you can. A 5 : 1 ratio should need 3 bags of 90# portland. I dry mixed the vermiculite and portland by pouring the portland over the vermiculite and then mixing that. then add water to get oatmeal consistency.
HTH
TexmanTexman Kitchen
http://www.fornobravo.com/forum/f8/t...ild-17324.html -
Re: vermicrete
For every 10 parts vermiculite add about 3 parts water. I mix the cement and vermiculite dry first then add the water. You will lose around 20% in volume when you mix the water in so this needs to be accounted for.Kindled with zeal and fired with passion.Comment
