vermicrete
  • hearman
    • Sep 2013
    • 2
    vermicrete
    not sure that last posting posted -- I am attempting to calculate how much Portland cement and vermiculite I need to purchase. I have a 6 ft by 7 ft with a 4 inch depth. Need a 5 10 1 ratio -- any help?
  • texman
    • Nov 2009
    • 724
    Re: vermicrete
    Hman
    That sounds like 14 cf to me of vermiculite. Get some extra, maybe one or two cf if you can. A 5 : 1 ratio should need 3 bags of 90# portland. I dry mixed the vermiculite and portland by pouring the portland over the vermiculite and then mixing that. then add water to get oatmeal consistency.
    HTH
    Texman
    Texman Kitchen
      • 9216
      Re: vermicrete
      For every 10 parts vermiculite add about 3 parts water. I mix the cement and vermiculite dry first then add the water. You will lose around 20% in volume when you mix the water in so this needs to be accounted for.
