Yes apologies to Sam,
Interesting about sticky rice, I have heard about this before but know little about it.
Some tennis courts are made with calcined clay and can be bought cheaply. In India, "shukri" which is burned clay and then crushed, is still produced traditionally as a pozzolanic additive. Brick dust are available in some countries and is a cheap alternative. There have been some fairly recent studies such as the “Smeaton Project” which have suggested that brick dust with a range of particle sizes between 38 and 600 microns more successful, and that the smaller particles, probably those less than 75 microns, tended to be pozzolanic. A brick dust can also aid carbonation of a lime mortar due to its porous structure.
The cement industry is amongst the worlds largest pollutants, the energy used to produce a pozzolan is far less. Recent research within the cement industry have suggested that by replacing a percentage of cement in the manufacture of concrete with a pozzolan will make a worldwide difference to emissions. With the millions of tons of concrete produced daily worldwide, this is an environmentally friendlier option. Pozzolans are added to cement today for this reason.
Of course if cement is available then use it. However, a lime, sand, clay mortar with an added pozzolan is a good option, and due to brick dust being a clay make for a good oven mortar.
