Recommended changes
This is a sticky topic.
  • #31
    Re: Recommended changes
    Thats how its spelt everywhere.....
    Everywhere EXCEPT the US.
    Unless you consider the US nowhere, which is a distinct possibility.
    Last edited by david s; 05-27-2012, 03:33 AM. Reason: Thought of more smart arse comments.
    • #32
      As the soldier course weakens the base of the dome and ovens are prone to vertical cracks at the base. Suggest that it be replaces by two rows of bricks laid flat if folk want the extra height at the base of the dome.
      • #33
        So solider courses should be avoided? just lay the first coarse down?
        • #34
          Brickie,
          In American English: spelt =spelled! You can't cover the entire world in Vegemite or Roo poo.
          • #35
            "Everywhere EXCEPT the US.
            You really need to learn how add emoticons to your posts
            Or someone might just take you seriously,
            FU
            • #36
              Many ovens have been built with them. A true radius will give you the best strength. What the solider course gives you really isn't that much at the end of the day. I got to admit that they look pretty cool.
              • #37
                What do you mean by "true radius"?
                • #38
                  A simi-circle. If you are building a 42 inch, it starts at the hearth (0) climbs to 21 inches at the apex (center) then back to 0. It's the best you can get for load distribution.
                  • #39
                    FU
                    My apologies,
                    Actually with the spread of American culture globally, I should have said "everywhere"
                    • #40
                      Soldier or sailor courses are fine when they are used with the construction method they were designed for. That is to say, if you are using either, then you have to have external buttressing of the sailor or soldier.
                      Low dome Neapolitan ovens use a soldier or sailor to flatten the roof of the dome and bring it closer to the floor while maintaining workability. They also use a monocoque external shell filled with medium density insulating material to reinforce the dome.
                      • #41
                        I agree, but two or three courses of bricks laid flat would be preferable to having long vertical joints at the base of the dome.
                        • #42
                          Ahh ok thanks guys, i think i will have my first course just sitting down/sailor
                          • #43
                            No, sailors are standing up, side by side, unless they are dead or drunk.
                            That second part is a joke ( the emoticons don't seem to work for me)
                            • #44
                              Really? Darn, i got them mixed up, so soldiers are laying flat down, and that is what recommended?
                              • #45
                                You have to turn them on in your CP....
                                My Build.
                                Books.
