Brick chimney to metal flue
  • stonecutter
    • Jun 2007
    • 2003
    #16
    Re: Brick chimney to metal flue
    Originally posted by V-wiz
    I just may spray the inside as well. Are you referring to the rust from the build of the soot/acid?
    I thought the outside was painted with high temp already..you definitely should coat the inside of that chase.
    Not only the soot, but the temperature fluctuations are going to create condensation, the heat will negate the galvanized finish in a relatively short time.
    Old World Stone & Garden
    John Ruskin
      Originally posted by david s
      The reason stainless is recommended is that heaps of people using galvanized have had to replace their flues after a few years service. Some prayer may help.
      You could fabricate and fit an inner sleeve in stainless.
      • Tscarborough
        • Oct 2009
        • 3341
        #18
        Flue gas is also highly acidic.
        • V-wiz
          • Oct 2012
          • 737
          #19
          Using stainless would have been very expensive for this application, but i would have loved to use SS, sure. Prayer always helps
          • V-wiz
            • Oct 2012
            • 737
            #20
            Yes, the outside is painted with high temp paint. Thanks for the info, i will also coat the inside.
            • V-wiz
              • Oct 2012
              • 737
              #21
              Yup, and combustible. Ask me how i know. My profession involves construction and inspections for a restoration company. I am very familiar with that. Ill just have to clean the flue every few years, or if i have to ill shell out another $140 and have another one made.
