Reading post after post, lots of info in this forum, awesome. Another question I have is in regards to semi circular openings. Is a 20 in wide semi circular opening , which would be 10 in high enough for a 42 in semi circular dome? You could add another 2.5 inches of height to each jamb to get to 12.5 in. Has anyone constructed an oven with these dimensions? I personally like the looks of a semi circular arch.
Semi- circular openings
Re: Semi- circular openings
Hi Campmaki
Amac did a semi-circular entry and it turned out very well. Follow this link:
http://www.fornobravo.com/forum/f8/3...eii-17334.htmlSharkey.
When you say jamb, do you mean a segmental arch opening? Or are you building a semi-circular arch? Because you can increase the rise by bringing the radial line higher on the center line.Old World Stone & Garden
John Ruskin
Stoecutter, when I said jamb I meant side. Strike the arch with a string, 10 in. radius then just add 2.5 inches or brick under the semicircular strike. thanks StonecutterOriginally posted by stonecutter View PostWhen you say jamb, do you mean a segmental arch opening? Or are you building a semi-circular arch? Because you can increase the rise by bringing the radial line higher on the center line.
My mistake when you have a semi circular arch you in essence do not have sides or jambs as call them. Just would add 2.5 in. ,then put semi on top of it.Thanks againOriginally posted by Campmaki View PostStoecutter, when I said jamb I meant side. Strike the arch with a string, 10 in. radius then just add 2.5 inches or brick under the semicircular strike. thanks Stonecutter
I understand, your spring line for the radius starts 2.5" above the floor.Old World Stone & Garden
John Ruskin
"Jambs",............."Carpenter" huh,Originally posted by Campmaki View PostMy mistake when you have a semi circular arch you in essence do not have sides or jambs as call them. Just would add 2.5 in. ,then put semi on top of it.Thanks again
It's all right by me. I grew up in a carpenter family. We built homes from the foundation up. That meant: footers, slab, septic tanks, fraiming, roofing, fireplaces, wiring, BBQ pits, etc. etc.
It ain't easy "meshing" all the "trade names" + the "local terms" in to my posts, as well
Gulf, actually I am a 32 yr. veteran mason building his first oven. Should be fun and go fairly quick for me. Building it at my summer home on weekends at a campground. Sorry about the construction slang, lol WayneOriginally posted by Gulf View Post"Jambs",............."Carpenter" huh,
I also like the appearance of a semicircular opening but I also wanted a large opening to allow me to slide turkeys and beer can chickens through the entry way. So I compromised...
I created a semicircular opening on the outer arch (where you can see it) and a shallower arch with vertical "jambs" on the inside to maximize my opening size. I think my inner arch is 12.5" tall x 20" wide (10" vertical jambs) and my outer semicircle is 13.5" tall x 22" wide.
Good luck and post some pictures.
Regards,
AT
