Does anyone have links to where I can order refractory mortar?
Refractory Mortar
Buckley Rumford Co.
They make fireplace parts and can provide you with a list of distributors also.
PRODUCTION QUESTIONS
Superior Clay Corporation
PO Box 352
Uhrichsville, Ohio 44683
800 848 6166 or 740 922 4122 (fax 740 922 6626)
Email Superior Clay
catalog@superiorclay.com
Heat Stop
That refractory mortar is called Heat Stop, and should work fine.
Or, you can make the fireclay mortar described in the plans, which is fireclay (ground up firebricks), sand and portland cement. It is not a true refractory mortar, because is it based on portland cement, but it will take the heat your oven will put out and you can easily find the components.
We are going to be getting more Refrax in California, which is Italy's biggest refractory mortar brand, and really nice. I will make a posting when it is back in stock. It's $25 for 22lb (just add water). It's great stuff and made specifically for brick ovens and fireplaces. Our oven producer makes it.
re:refractory mortar
Explore Alsey Refractories Co. for top-quality firebrick and refractory products, comprehensive product and safety data sheets, and expert solutions for industrial and residential applications. Learn more today!
Here is another company that has 50lbs bags for about $50 and will ship it -also has fireclay.
