Finally! after 2 years of reading on the Forum I have started my new 42" oven build. I built the base for oven 7 x 6.5 ft. and added 2 prep areas 3ft by 21 inches. I made it so there is a walk in are to get to the oven. I just finished adding concrete to the cinderblock with rebar and starting the framing for hearth slab. I added a large angle iron in the middle for support that the hearth slab gets poured right onto. Please give any input or suggestions!
Thank you,
Chris
Thank you,
Chris
