7 years in the waiting i get to start my 42" pompeii
  • leetheldc
    Re: 7 years in the waiting i get to start my 42" pompeii
    thanks carl Im at roof point now so get water tight and I will be insulating the dome
  • NCMan
    Lee.....looking great and lots of progress!!
  • leetheldc
    back at the oven this weekend after some time away due to family parties I managed to get the chimney on the bbq/fireplace done the last 2 post for the roof set in and today the oven chimney brickwork up il put the twin wall in at a latter date I need to get it ordered
ID:	308408 I also managed to bag my roof tiles from ebay more than enough to do the job plus a wet polisher for the counters when I get there!
  • NCMan
    Looking great, Lee!! I can see why you're a bit tired of arches.....
  • leetheldc
    here are todays pics of closing the bbq/fireplace was a bit of a milestone day as no more bloody arches no more tapper cuts this is arch no 7 of my effort and im done with em our lass got a pic of my happiness as a layed the final keystone the hair shows the bloody sturggle it was to get there!
    the hole for the chimney is about 260mm by 250mm but with it having a hood im hoping it draws ok just ready for a couple of chimneys now then its roof time
  • leetheldc
    Originally posted by NCMan
    Lee......great progress and some great looking work!! You're getting there!
    yes carl slowly but i can see the light.
    not had chance to post for a week or so but made some more slow progress. weathers been a nightmere rain all day yesterday killed play time. but sun was out today and finaly managed to get the bbq closed in last weekend i got the forms all made and a few course to help the front low arch go over over the next coupe of days with a short day at work i got the front cut done. I used a bit of string from the centre of the radius with some tape stuck around it at the right point for the cut you can just see it in the 1st pic im hoping to create some form of smoke shelf at the start of the hoodon the sides you can see the forms sit on a course of brick that will hopefully do this and keep the smoke up ther for the cimney to suck it up the forms will be a nightmere to get out though but il sort itClick image for larger version
  • NCMan
  • leetheldc
    just a quick progress update finished early on friday so managed to get the back of the dome arch finished all squared up ready for a chimney same process 2 cans of stella and take the form out leaving a nice gap for insulation Click image for larger version
    then i got a couple of hours on saturday to see where i was going with the fireplace/bbq had a full day today against the rain at times and made some good progresswith the bicks. got the back wall up and cut to recieve the arch just the front to do then get the sides rolled over also cobbled out some bricks on the ouside so i could get a good sized counter shelf on the side.
  • leetheldc
    Still no joy of the iphone uploading 2 pics at once
  • leetheldc
    3 cans of stella later and I couldn't stop thinking about the mortar joints under the arch form so I went for it dropped out a treat and there was enough mortar in the entry way for me to point it all up keeping the mortar as one and not putting new on top of old tomorrow Click image for larger version
  • leetheldc
    Another shot from the front flash didn't bloody work though
  • leetheldc
    There was no way I was losing all them cuts Carl I had another try at dry laying it and it seemed to work so a few more cuts this morning and I've now earned my stella long bloody day it has been but worth the effort I think ended up pointing in the dark so hope it's ok Click image for larger version
  • NCMan
    Looking good, Lee. At this point, you can either consider adjusting your joint spacing, make or buy a custom keystone, cutting a new arch template, or start over. It'd be a shame to start over, after doing all that cutting. If it were me, I'd at least look into adjusting your joints and/or making a new template. That's the cheapest and easiest way to go. If you can't live w/that, then consider making or buying a keystone. A different type/color/style of keystone can, at times, make a nice complimentary feature to an oven, if that is an option for you. Best of luck.
  • leetheldc
    Already done that one David think they sick off waiting!! Getting through the cuts had enough dine for a dry lay not workin out as should so bit of head scratching to be done I may have to make a custom keystone if I can't re jig them Click image for larger version
  • DavidApp
    Bribe the neighbor with the promise of Pizza when the oven is done.
    David
