A Real Newbie question
  • A Real Newbie question
    Hi all,
    I'm about to mix and pour the the 3 1/2 inch concrete hearth, per the Pompei oven PDF. But before I do, I want to be quite sure that I'm using the right concrete.
    I plan on using Sakrete High Strength Concrete mix, which is a mix of gravel, sand and portland cement, I assume in a 3 -2-1 ratio.
    Am I missing the boat here? Should I be using just sand and cement?
    Please advise...
    Re: A Real Newbie question
    You do NOT want just sand and cement.
    High Strength Concrete mix sounds like the right product.
    I wouldn't recommend fast setting concrete.
    Have you already built the stand? Or is this pour the foundation under a stand? What reinforcement are you using? What did you do for drainage? (I assume that'll be a potential problem in FL)
    Some advice: Start a build thread. Post lots of pictures.
      yes, you want high strength concrete mix. 3 1/2 inches is reasonably thin. High strength concrete is used for counter-tops and is especially important to use if you have any parts of the heath that extend out and are not directly supported underneath.
        Thanks for the responses.
        I thought Sakrete was the right product, but I wanted to be sure, before I lugged 18 more bags of concrete from the Depot.
        As I noted, this slab will be for the hearth. The slab for the base has already been poured and the blocks stacked, filled and bond coated. once I get the hearth poured, I will finally be able to start the fun stuff.
        I'll start to post pictures as soon as I have something that is recognizable as the beginnings of pizza oven.
        Thx and regards
          You are probably on track and doing it but if not, make sure and use rebar. There is a lot of weight on the hearth slab. More weight than people realize.
            Hi Novaslo
            Listen to all the above and I will add once the base is layed, troweled and now going off if it is extremely hot I would, like I did put some wet towels over it and keep them wet. I did this for a fortnight so it goes off slowly. But it was 40C when I layed mine for about a month [or at least it seemed like that]. Haven't got one crack not even a hairline one but then again mine is over 12inch thick [due to position more than anything].
            Cheers
            Cheers Colin
