Re: Northwest PA 36" oven build
G'day
I suppose the race is on to finish and cure. Remember as the oven drys the heat goes up anyway as that moisture gets displaced . Try to keep that fire the same size till you don't get a raise in temps then ramp up the fire.
How's the humidity now ? I recon if its cold and not due rain the humidity would be low as well? If it is great, its in your favor.
G'day
