Out of work Pizza Man's 42" Build in NJ
  • spiderrinaldi
    • Sep 2014
    • 38
    #31
    Re: Out of work Pizza Man's 42" Build in NJ
    I have been working hard to get this oven dome done. I have almost completed 6 courses and the soldier course, for a total of 7. Things appear to be going well. I installed the opening archway. I cut the archway bricks using Amac's "3 cut" advice (I actually measured the lines of the cut on my computer monitor and converted for my brick size to figure out exactly how to cut). Thank you to everyone who has contributed. I used design ideas from many other builds. Overall, the build is a little sloppy. Wish I would have scraped off the mortar from the inside of the soldier course. I let it dry and it is extremely difficult to remove now unless I use my angle grinder. What will that mortar do once the oven gets fired up?
    Take a look at my pics.
    • spiderrinaldi
      • Sep 2014
      • 38
      #32
      Here are more progress pics.
      • Greenman
        • Feb 2013
        • 1123
        #33
        It is a little difficult to tell from your pics but it appears that the angle that your IT is setting your bricks is a little less than what is needed to avoid the bottom of the brick protruding from the course below it.
        Other than that it seems to be coming together fine. The exposed mortar on your soldier course will probably spall off to an extent over time. It is difficult to clean it up after it has set properly.
        Cheers ......... Steve
        • deejayoh
          • Jul 2010
          • 1893
          #34
          Looks like really great progress. I'd suggest getting some cardboard or something over your oven floor to keep it clean and avoid chips. Also, echoing Greenman's comment it still looks like your IT axis is maybe not hitting the bricks in the middle of each course. You're getting a bit of stagger
          • spiderrinaldi
            • Sep 2014
            • 38
            #35
            Yes, I am getting some overlay of the bricks. A little thing that I would certainly correct if I ever build a second oven. As long as the oven works and does not fall apart, I will be happy. I fully expect cracks to form. Even the best builders on this forum have them, so I am not too concerned with that. As long as I can make the oven aesthetically pleasing by enclosing the dome and putting on a veneer finish, my wife will be happy and won't tell me to tear it down!
            • spiderrinaldi
              • Sep 2014
              • 38
              #36
              Oh no. Bad news. My HF saw's pump motor seemed to die. It's not pumping. Has this happened to anyone else?
              • deejayoh
                • Jul 2010
                • 1893
                #37
                My never died but it did plug up quite a bit. You can get a new one for about 8 bucks.
                158 GPH Miniature Submersible Fountain Pump
                  • 5260
                  #38
                  I found that if you put the pump in a 5 gallon bucket of clean water then you don't get all the sediment in the pump.
                  • spiderrinaldi
                    • Sep 2014
                    • 38
                    #39
                    I actually took that advice and had the pump in a separate 5 gallon bucket.
                    I was able to get it to work again. I took off the cover and saw that the mechanism under the filter was trying to start to spin but couldn't. I got a thin screwdriver and gave it a few nudges and it began to spin. Back in business.
                    • spiderrinaldi
                      • Sep 2014
                      • 38
                      #40
                      Starting to think about what to use for a chimney. I just posted a separate thread posing a couple of questions.
                      http://www.fornobravo.com/forum/f44/...tml#post180810
                      • spiderrinaldi
                        • Sep 2014
                        • 38
                        #41
                        I have just about run out of fire clay and the source where I bought my first bag won't have it until next week. I have about 1 and a half courses left and the keystone. I may switch to Heatstop to do the last little bit. I can get a 12 lb bag for $30 which isn't bad.
                        • Tonyp
                          • Jan 2009
                          • 165
                          #42
                          Do you mean the 10lb premixed pail? It might take a couple of them to do that much..
                          Why not just use the muck at the bottom of your HF wet saw tray for the fireclay?
                          Tony
                          Link to my oven build thread:
                          40 inch indoor pompeii in NNY
                          • spiderrinaldi
                            • Sep 2014
                            • 38
                            #43
                            I've been washing it out every day, so no dice. Didn't bother saving it.
                            • Tonyp
                              • Jan 2009
                              • 165
                              #44
                              Oh ;<
                              Hmm well if you have some small brick cut off bits you could turn them into dust with the wet saw!
                              Tony
                              • deejayoh
                                • Jul 2010
                                • 1893
                                #45
                                Re: Out of work Pizza Man's 42&quot; Build in NJ
                                Cut a few more bricks and you'll have more. Buying fire clay and/or HS isn't worth it!
