Does one add Sand to HEAT STOP 50 (Dry in 50lb bag)
  • ocafra
    • May 2014
    • 25
    Directions on bag says to just add water, but I keep reading about adding sand to the 3.1.1.1 home made mixture.....not sure if I should be adding sand (like small rocks to cement), or leave the premix as is and just add water.
    Frank
  • NCMan
    • Jan 2014
    • 846
    Re: Does one add Sand to HEAT STOP 50 (Dry in 50lb bag)
    Just add water.
    My Build:
    • ocafra
      • May 2014
      • 25
      Much appreciated!!!
