We are at the enclosure part of our oven. We are using concrete block on the upper portion (hearth to the enclosure roof) of the oven. We will wrap 3 - 1" layers of Forno Bravo insulation blanket on the dome.
1) Do you recommend I also pour in dry insulation over the blanket?
2) Should I use Vermiculite or Perlite or a combination of both?
3) How thick should the Vermiculite/Perlite be?
Thanks,
Pam
Thanks,
Pam
