My plan is to have my barbecue the same height as the hearth floor. I am now wandering if my approach has compromised the strength. The plans have a little more than an inch of concrete below the steel and above the block where I have the steel setting on the block - hopefully the picture helps this make sense. Do you think the sheer strength of the steel alone is adequate to support the weight?
Thanks,
Les...
Thanks,
Les...
