Dome collapse - advice needed
  • KISS4me
    • Sep 2006
    • 51
    Help please
    I thought I was going well with my dome construction (see photo at http://www.fornobravo.com/forum/phot...ndex.php?n=286) until I went to finish the top half and
    1. It looked like Noddy's hat.
    2. It collapsed when I took down form.
    I reckon my problem is that each of my layers were flat topped (oven inside brick face always 90 degrees to oven floor) creating a stepped effect with each layer. Am I correct in thinking that after the first layer these should start to tilt towards centre of oven? If so, is it best to use a wedge of mortar or brick wedges under second layer to get this going?
    A dejected but not beaten Steve
  • Dutchoven
    • Apr 2007
    • 931
    Re: Dome collapse - advice needed
    Yes, definitely should have a bit of roll to each succeeding course. That way the weight of the bricks is thrusting out toward the bottom course of bricks. I think you can begin with an angled first course in a soldier pattern. That will "spring" the angle for your dome. You should then be able to use a removeable shim that should prbably taper from about 3/8" to 0" you can then set the mortar alongside the shim and tap your brick into place, then when you remove the shim you can back fill the space with mortar. This method would get you most of the way up in your dome without forms, that is until gravity takes over. It will also help to make sure that you have a bit of a "keystone" that will lock each ring in place.
    Hope this helps.
    Dutch
    • wlively
      • May 2005
      • 384
      I recommend laying out a test "slice" on table or board. Since I was building a 42 dia oven I took a scrap piece of plywood and drew a 21 inch (half of 42) L with and T-square and then made a 21 inch arc to connect top and bottom. If you want a flatter arc then draw whatever shape you want. Then you can lay out your bricks and see how they have to be positioned to follow the arc. You could also use it to see what size wedges you will need, but you don't have to get that fancy unless you want.
      I have a digital smart level. From my board I was able to work out that each course would be +7.5 degrees. So I took whatever cut wedges I had lying around the saw and pushed them in however needed to make my 7.5 degrees. Once I got the hang of it I only needed to measure the first brick of a ring and every 5th or 6th after that.
      Wade Lively
      • Bacterium
        • Apr 2007
        • 560
        just adding to what has bee said so far, Steve....
        Yes the top of brick must be angled in as you go up. It is a bit tricky getting them into the right wedge shapes. I cut most of mine (solid red clay bricks) with a bolster and then chipped off the odd bit with a brickys hammers (long flat pointed end). You can always use a small grinder with a diamond blade or a brick saw but with this sort of brick its possible with hand tools...yet tricky.
        How are you doing that last top bit......are you building a sand cap inside (just top half) as a support for the top section of bricks?
        The other trick is when to pull out the dome cap formwork(assuming you use one) after you have laid up the last bricks. Sure if the bricks are interlocked properly it should stay up but its not always that simple (as you know). I found mine took about 2 hours of drying time. The mortar was fairly firm yet still had enough give in it - in case you had to make any adjustments from inside OR when you are removing excess mortar and cleaning up inside with a sponge etc.
        have a look at some of my pics here:
        you are nearly there....
        Damon
        Build #1
        Build #2 (Current)
        • Bacterium
          • Apr 2007
          • 560
          o yeah....if you are going to join the dome with the front arch get some brick ties in to get the two to bond together. Usually AUS$0.45 ea at a local landscape supplier, building supplies or larger hardware.
          Damon
          Build #1
          Build #2 (Current)
          • wlively
            • May 2005
            • 384
            One more tip myself.
            Did not have any problems with the bricks staying put till about the 6th course. Wanted to keep things simple, so used short 2x4's with a nail in one end to catch the brick face and keep the brick in place. Then it hit me, why not move the floor? So, I cut a piece of my pink foam board to be exactly the same size as the top of the complete ring. Then got a small scrap square of plywood and drilled a hole in the center of each. I have some long all-thread and with a nut and washer wallah, a jackscrew if you will. So that propped up my "floor" and simply place bricks in place. When you finish with one ring simply cut the foamboard down to the next size and repeat.
            Not saying it is a better way, just a real easy way that worked well for me.
            Wade Lively
            • Archena
              • Apr 2007
              • 1214
              Um, how did you get it out?
              [/CENTER]
              • Dutchoven
                • Apr 2007
                • 931
                Well Wade all I have to say is you have some fantastic ideas man. Definitely an out of the box thinker. I am glad you got in the plywood form as I forgot to mention it. Cutting each brick works very well also and keeps mortar joints nice and thin, could almost dip them. Cutting would be very tricky and I would suggest saving the cutting for the sides to make them fit nice in each ring and take care of the roll using mortar.
                Best of luck
                Dutch
                • Hendo
                  • Oct 2006
                  • 257
                  Steve,
                  I noticed in some earlier photo's on your photostream that you fabricated a dome gauge, as per Russell Jeavons' suggestion. This theoretically makes it straight forward to get the angles right for the second and subsequent courses, right through to last couple of rings or so.
                  See page 19 of Russell's book for a diagram of how the dome gauge is used, course by course. I have no experience with using a gauge like this, nor will I, as I'm using tapered bricks which should form a natural arch by themselves (fingers crossed!).
                  As for the last few rings, I like Wade's brilliant idea of using a reducing circular template to support the bricks in each course - I'll definitely be trying that one myself!
                  Cheers, Paul.
                  • Bacterium
                    • Apr 2007
                    • 560
                    KISS4me - I'm looking at your "Dome mold" photo, it looks like you are going by Russells suggestion - As Hendo rightly alludes to.
                    What I found is I didn't bother using mortar (cement) in the mold mix (Russell suggests mortar). I just used brickies sand which is coarser and has clay in it. Dampen it enough and it shapes fine and holds for a few days. It's easier to clean and you can reuse the sand if careful.
                    With laying the bricks....
                    We (Brickie mate and I) found instead of buttering the bricks and then putting them down, put them down first - angle the back of it up and "flick" in your mortar from the trowel. Then with a rubber mallet give it a small tap - down and up against the adjacent one.
                    We only ended up cutting the last one in each circle (course) and on the last circle it got tricky.
                    ...mmm.....hope this helps....sorry if you already know this....I?m keen to see you succeed.
                    Hendo.....I'm guessing even with tapered bricks you would need to build some sort of mold to hold it(or other method). As there would be a point where each top course (ring) would want to slide in due to gravity. Sure once the dome is up it would all hold up. Same principle as a brick archway.
                    Best thing someone said to me was "Its a brick oven - not a mortar oven"......then it all fell into place - oooopppsss no pun intended KISS4me
                    Damon
                    Build #1
                    Build #2 (Current)
                    • wlively
                      • May 2005
                      • 384
                      Unscrew the nut enough to lower the "floor" clear of the top course and pull all-thread out of hole. Then you take the pieces out the doorway or in my case rotate and out the top as I did not use bricks for the dome cap. See here for pictures.
                      Thanks all for the compliments, I get lucky every now and again.
                      Wade Lively
                      • KISS4me
                        • Sep 2006
                        • 51
                        Thanks for the excellent responses.
                        Looks like instead of eating pizza from my oven this weekend I will be eating humble pie and knocking it all down back to the first course, cleaning the bricks and starting again.
                        I feel pretty daft about the way I went about misusing the gauge as shown in photo. Thanks to the advice from this forum I now feel a lot better going again.
                        A couple of follow-up questions:
                        1. Damon's tip as to not buttering bricks will certainly save some time and sounds like a good idea. Does this mean that you used no mortar on the sides of each brick and rely on the mortar wedge heaped in from behind to bind the bricks?
                        2. Wade - do you have any photos of your reducing circular template idea?
                        A much appreciative Steve
                        • james
                          Brick Oven Merchant
                          • Mar 2005
                          • 4648
                          Keep going Steve. I had the dome of my Scott oven fall in the first time I built an oven, it's a lot easier the second time. You've tackled the learning curve -- a huge part of the project.
                          Wade, I would like to see your photos -- and maybe include them in the V2.0 release of the Pompeii e-Book. Thanks!
                          • Archena
                            • Apr 2007
                            • 1214
                            Thanks!!!!
                            [/CENTER]
                            • wlively
                              • May 2005
                              • 384
                              Steve
                              I will reassemble my contraption and take a few pictures for you, but the floor will be pretty small. In fact that is what my plug is sitting on in my oven posts.
                              I am sorry though I may not be able to get them until wednesday. When I am working, I do 14 hrs days and don't have much time for much else.
                              I did butter my bricks when installing, but was careful not to butter the front face and applied it in a wedge similar to what the final shape would be. I personally felt better seeing the mortar ooze out, knowing I had enough in there.
                              Wade Lively
