Re: Begining dome construction
That's another really cool thing about these ovens. Power failure is still difficult, but it doesn't hit you half as hard as it would without an oven!
Good to hear you're all ok!
Unfortunately its a good for nothing pine. One good thing about the storm was that I now have plenty of kindling from the fallen dead branches. Also there are hundreds of people giving away oak from fallen trees. Will be great for next yr. Plan to fire up the oven tomorrow for pizza, bread, and roasts. I may not have power but i can still cook!
What kind of tree is that? Perhaps you have some pizza fuel!
Hey, just trying to be optimistic. Seriously, though, we are glad everyone's OK. These storms are getting to be scary!
Everyone's alive and well...was damn scary though. Still no running water, phone, or electricity at the house though. The oven weathered the storm quite well....the house wasn't so lucky....3 Photos
We're pulling for you all. Stay safe.
Preparing for a Cat 3 hurricane. Hopefully the tarp and tie downs hold. The perlicrete only covers half of the dome so far, so I can't afford for the blanket to get soaked, or worse, blown away.1 Photo
Finally got around to adding the perlite concrete to the dome. Slowly but surely...2 Photos
I actually tried dry assembling my geodesic oven on the workshop floor. If it were a full dome it might be stable enough to do that, but that big hole in the side sets up a lot of stresses in the structure. I think mortar is a must.Would it be better if you could build an oven with no mortar. If you could make it stand up! I know its probably not possible, but if you could.....
Thanks! Feel free to look me up if you're ever around.
I did another fire yesterday with my first log. The floor bricks got to about 200F and the oven dome topped out at 250, if I remember correctly. The dome was back down to 100F this morning (normal day temp here). I'll try to hit 300F on the dome this afternoon...don't want to bring the temp up too much too fast.
Don't worry...if it is masonry it will crack...early in the curing there is still quite a bit of moisture in the mortar and the steam has a way of creating them...they will stabilize over time...you did a very good job on your oven...continue a nice cure and soon you'll be enjoying the fruits of those labors...I have a brother in Houston, well Katy actually...if I ever go visit him maybe we can meet upOriginally posted by rlf5 View PostPictures of the crack propagation.
Best
Dutch
Pictures of the crack propagation.5 Photos
Thermocouples installed and second fire. The termocouples on the right and left only go 50% through the floor bricks. The one in the center sits flush with the oven floor. There's also one that goes into the dome and is about 1/4 inch from the inside oven wall.4 Photos
The bottom form removed and first fire.4 Photos
Well the pour went rather well, and came out better than expected. I let it set for about 5 days (highs in the mid 90's here) and then started doing the curing fires. I would use a few pieces of newspaper only. The paper of course burned rather quickly and the oven temperature would be back down in a few hrs, so I did about 3-4 newspaper fires over the course of two days. No problems. Then I switched it up to newspaper and small twigs (between 1/8" up to 3/4" thickness.) That fire of course burned hotter and a bit longer. I kept that fire going for about an hour or so by adding to it so that I could keep a more or less constant temperature in the oven. I found that the newspaper fires would get the dome up to about 120F and the kindling fire up to around 200. I did one last kindling fire yesterday evening for about 2 hrs, which got the dome up to 225F. That last fire actually manifested a few cracks in the thin clad of mortar I applied. I imagine they are in the joints as well, but of course I can't see it. Oddly enough, there were no cracks at all in the cast dome cap. It seems to be curing nicely so far. This morning the dome temperature was down to 95F and the cracks had settled down to just hairline fractures. I'll most likely do one or two more kindling fires before moving up to logs.4 Photos
I was using one, and then stopped (real smart, huh?). I got a bit off on the angle for the bricks on the left side, and then tried to correct for it on the next course. Seems the correction is actually the source of my woes! Anyway, unfortunately I already started casting the oven cap. I pondered on it for about a week when it was raining here. Its actually not that big of a piece...just too big to fit into my kitchen oven. Its also reinforced with steel needles so I doubt it would fall apart. The only thing I'm worried about are cracks that would form from single side conduction heating during the curing. I was just really tired of cutting bricks, and the break from doing it didn't make things better. Laying them is actually fun...cutting sucks for me...and specialized cutting sucks even more. If the cast doesn't work I'll be cutting anyway! LOL
