Well I started cutting bricks yesterday for the dome (thanks Hendo for the tips). These shown will actually be the oven floor level course. I plan on stacking them on top of the oven floor so that I can trace were to cut. I also have a box of insulating board that needs to be put in under the oven floor.
Begining dome construction
Tags: None
Re: Begining dome construction
Rest of the pics3 Photos
Looks good!
What kind of mortar are you going to be using? When you are cutting and laying out your first course, don't forget to figure in the width of the mortar joint. If you lay the bricks out perfectly with the edges touching, your final result with the mortar will be a larger diameter circle than what you planned.
Edit... After looking at your photos more closely, it appears you might have left some gaps in there. I really like the way the tapered cut bricks look. I can't wait to start cutting!
KenLast edited by Ken524; 08-24-2007, 09:17 AM.Ken H. - Kentucky
42" Pompeii
Ken
I know in the upper layers it is hard to avoid joints that grow larger, but on the bottom layers don't you want the bricks touching on the inside or should there be a bit of mortar on the inside edge?
Would it be better if you could build an oven with no mortar. If you could make it stand up! I know its probably not possible, but if you could.....
Originally posted by asudavew View PostWould it be better if you could build an oven with no mortar.Ken H. - Kentucky
42" Pompeii
RL,
I noticed you have the saw pump in the tray. This was a source of great pain. The pump kept failing because of the "mud". I hung a 5 gallon bucket off the back of the saw and dropped the pump into that. Haven?t had a problem ever since. Just a suggestion.
Les?Check out my pictures here:
Ken
Les?
Havn't had any problems yet, but I may just try your suggestion. Thanks!
Finished cutting the rest of the surrounding floor bricks. I'll line them up a little better and then trace the ID onto the oven floor bricks so I can cut those.2 Photos
Looks great!
I'm starting to get jealous....because I haven't started yet!
I am curious though, how many fire bricks did you buy?
Only bought 150. Although I didn't get enough...I'll probably need 50-75 more.Last edited by rlf5; 08-25-2007, 06:59 AM.
Finally got a break in the rain and decided to jump on some brick cutting. I got about half of the floor bricks cut so that the wall bricks fit around them. I'll do the rest tomorrow.2 Photos
Rl,
We are at the exact same stage - the race is on!Check out my pictures here:
I actually think you're a bit ahead of me. I still need to cut the other half of the floor bricks, and I still may add another 2" of insulation to the bottom. Still deciding on the latter task.
