Begining dome construction
  • Begining dome construction
    Well I started cutting bricks yesterday for the dome (thanks Hendo for the tips). These shown will actually be the oven floor level course. I plan on stacking them on top of the oven floor so that I can trace were to cut. I also have a box of insulating board that needs to be put in under the oven floor.
    Oven Progress
    Bread Photos
    Oven Stand Thread
    Re: Begining dome construction
    Rest of the pics
    Oven Progress
    Bread Photos
    Oven Stand Thread
      Looks good!
      What kind of mortar are you going to be using? When you are cutting and laying out your first course, don't forget to figure in the width of the mortar joint. If you lay the bricks out perfectly with the edges touching, your final result with the mortar will be a larger diameter circle than what you planned.
      Edit... After looking at your photos more closely, it appears you might have left some gaps in there. I really like the way the tapered cut bricks look. I can't wait to start cutting!
      Ken
      Ken H. - Kentucky
      42" Pompeii
        Originally posted by Ken524 View Post
        Looks good!
        Ken
        Hey Ken I have a question related to this.
        I know in the upper layers it is hard to avoid joints that grow larger, but on the bottom layers don't you want the bricks touching on the inside or should there be a bit of mortar on the inside edge?
        Would it be better if you could build an oven with no mortar. If you could make it stand up! I know its probably not possible, but if you could.....
        My thread:
        My costs:
        My pics:
          Yeah! That would be the perfect oven I would think.
          Ken H. - Kentucky
          42" Pompeii
            RL,
            I noticed you have the saw pump in the tray. This was a source of great pain. The pump kept failing because of the "mud". I hung a 5 gallon bucket off the back of the saw and dropped the pump into that. Haven?t had a problem ever since. Just a suggestion.
            Les?
              Looks good!
              Ken
              Yea there's about a 2mm gap left in there for mortar. All my joints are going to be very tight fighting b/c of the taper. If i'm lucky I should be able to do the whole dome with one bag of mortar. Oh, to answer your question I ordered two bags of RefMix, which should be arriving soon.
              Oven Progress
              Bread Photos
              Oven Stand Thread
                Originally posted by Les View Post
                RL,
                Les?
                Les
                Havn't had any problems yet, but I may just try your suggestion. Thanks!
                Oven Progress
                Bread Photos
                Oven Stand Thread
                  Finished cutting the rest of the surrounding floor bricks. I'll line them up a little better and then trace the ID onto the oven floor bricks so I can cut those.
                  Oven Progress
                  Bread Photos
                  Oven Stand Thread
                    subscribed! thanks for posting.
                    Steve Kennemer
                    Austin, TX
                      Looks great!
                      I'm starting to get jealous....because I haven't started yet!
                      I am curious though, how many fire bricks did you buy?
                      My thread:
                      My costs:
                      My pics:
                        Only bought 150. Although I didn't get enough...I'll probably need 50-75 more.
                        Oven Progress
                        Bread Photos
                        Oven Stand Thread
                          Finally got a break in the rain and decided to jump on some brick cutting. I got about half of the floor bricks cut so that the wall bricks fit around them. I'll do the rest tomorrow.
                          Oven Progress
                          Bread Photos
                          Oven Stand Thread
                            Rl,
                            We are at the exact same stage - the race is on!
                              I actually think you're a bit ahead of me. I still need to cut the other half of the floor bricks, and I still may add another 2" of insulation to the bottom. Still deciding on the latter task.
                              Oven Progress
                              Bread Photos
                              Oven Stand Thread
