I got the third coarse complete with the entry arch. In hind sight, I would not recommend this approach - a ton of cuts... It does appear to be working though. If I had it to do over, I think I would set the inside arch with brick ties and go from there. My thought was to get everything locked together on the entry - I achieved that. (I need to get back in the box)
You can check it out http://www.fornobravo.com/forum/photoplog/index.php?q=l
Les...
Les...
