Re: Acoma 42" Tuscan
I cut the lower chimney base bricks, and will mortar them later. I will do the upper base bricks tomorrow. I am curious, the base plate says to get mason screws and screw into the bricks, and to use high temp bonding material. Ken, James, etc....did you guys use screws with yours? Can I also use the Refmix to bond the plate?
