Keeping Concrete out of Cells
  • jamesdifede
    • Apr 2007
    • 11
    Hello All:
    Building First Oven here is Takoma Park Maryland. Got the cement blocks in place last weekend and filled the required "core cells" with concrete for strength. I hope to build the form for the first concrete layer this weekend.
    I have no idea if this question is way off the mark, but here goes:
    In pouring the intial concrete, can I expect that a bunch of it will pour through the open cells on the top of the last layer of cement blocks? It would seem like there would be a good deal of waste if much of the concrete pours through this rather wide openings.
    If anyone has a trick or technique to keep this from happening, it would be much appreciated. I will be snapping some pics this weekend, and hope to post early next week,
    Thanks very much in advance,
    Jim
  • dalucca2003
    • Aug 2006
    • 114
    Re: Keeping Concrete out of Cells
    Jim,
    I know a lot of people who just stuff their empty cement bags in the cells to fill the void or being one who went overboard on the cautious side, I filled every core with cement. I believe most builders opt for filling the empty cores with the bags or other loose material.
    • asudavew
      • Jul 2007
      • 1880
      Jim
      I filled my empty cells with the empty bags from the Sacrete that I used to fill the other cells. And then a bit of sand/gravel. Not much.
      You can fill em with just about anything to keep the hearth concrete from running into them.
      Sand, gravel, dirt, newspaper, a time capsule.... whatever is available.
      Congrats on the beginning of your oven! It's a heck of a fun project.
      Remember to post pics.(We like em around here)
      Good luck, and keep asking questions.
      My thread:
      My costs:
      My pics:
      • thebadger
        • Jun 2007
        • 383
        Jim,
        The plans recommend that you use old concrete bags to fill in the cores you don't want filled. I read there are plastic "fillers" but haven't found any yet.
        Good luck
        Dick
        • jamesdifede
          • Apr 2007
          • 11
          WHoa....those responses were quick and much appreciated. I guess a little common sense goes a long way....should have thought of that myself.
          Thank you for your replies. I will post as I go.
          Regards,
          Jim
