First fire in Wisconsin - Forno Bravo Forum: The Wood-Fired Oven Community
  • First fire in Wisconsin
    February has been a killer month in Wisconsin, with the most snow falling for the season since they started recording it and most of it hit in February. This weekend was the rarity with two days of above zero (F) temps, no winds and clear skies. So I decided to push back the tent and start the curing fires. I am using the approach James suggested recently with all day fires from 300 to 700 degrees over the course of 5 days.
    http://www.fornobravo.com/forum/f16/...tegy-3227.html
    So far (after all of one day), seems to be working out great. Love how the dome looks after the first fire. Interesting how each experience gets you focused on a different part of the forum. After spending WAY too long getting the initial fire started I am now hitting threads that focus on that part of the process.
    Jim
    Re: First fire in Wisconsin
    Congrats neighbor (with particular recognition for fortitude)....the post should be Firing in February....let it snow!
    Soon come the cooking fires and the good eatin....
      Congratulations Jim, I'm glad the weather broke for you to start. How are you monitoring the temp, IR gun or did you put in thermocouples?
      RCLake
      "It's time to go Vertical"
      Oven Thread
        I am using a combination of a thermocouple probe to measure ambient and a IR to measure various surfaces of dome, but after a very short time you get a sense for what size fire is required to maintain the temp. I am adding wood (small pieces) every 15 minutes or so.
        Jim
          Atta babe! Way to go Jim. Soon you will be switching you forum focus to Dave and his cooking shows!
          dusty
            Congratulations!!
            It'll be cool to see how this curing method works out for you. When's the first cook-up planned?
              JCG,
              How hard is it to maintain the temps according to the plan? Does it go up and down 100 degrees everytime you add wood then let it die down?
              George
              GJBingham
                Originally posted by gjbingham View Post
                JCG,
                George
                It hasn't been too difficult (although time consuming) because I am using small pieces (1/8 splits) and just adding two to three every 20 minutes or so.
                Put a 1/4 split on hoping I could extend the refresh time, but had to take it off because it moved the temp 50 degrees. So back to every 15-20.
                Jim
                  That's kind of what I thought would happen. Electric or gas heat curing would be easier to control, at least I think, for the newest curing plan.
                  GJBingham
                    I've just removed by supports below the hearth and am wondering what I'll do with all the 2x4s. Could they be used in the drying fires or would the creosite be an issue?
                    RCLake
                    Oven Thread
                      RC
                      I'd use them for kindling, drying fires and/or initial startup fires.....save good wood for cooking. Creosote should not be too bad since when you get to pizza temp the soot will burn off.
                      I burn pallet wood when I can find them for generating heat....other woods for cooking.
                        I've burned a ton of two by fours and construction garbage. Slow smokey fires are what cause creasote buildup, not high-heat fast fires.
                          I know this has been discussed somewhere...
                          No concerns about chemicals?
                          So pallets and 2/4's (untreated) are fine to use?
                          Yeehaw -- Free firewood!
                          My thread:
                          My costs:
                          My pics:
                            Yup. Although my oven is not yet built I have used a wide variety of wood in cooking. I remember seeing a thread about wood in Pompei ovens and the consensus was that the ovens are not really fussy. It was also univerally stated that treated lumber and telepone poles should not be used. My rule of thumb.. untreated stray wood for startups, "good" wood for cooking.
                              I haven't had any problems with burning pine. I figgured it wasn't a woodstove so I burn pine all the time until the last few logs I throw in some hardwood.
                              Chuck
