I am planning on making a door out of two sheets of cut metal plate with a block of Calsil in the middle. I bought some 2" ceramic fibre rope that I thought would make a nice bit of insulation round the outside but I'm not sure what to attach it with. Is this something for high temperature epoxy? Is it safe given this touches the hearth?
Ceramic fibre rope what to attach it with
Tags: None
I have been thinking along those lines myself. But, I am concerned about the exposed fibers of the rope. And, my door works pretty good without a soft seal.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build -
I think that for door gasket Rutland makes a product for this. I haven't used but have been thinking about adding. Comes with adhesive IIRCComment
Oh that's an idea. I've ordered a bit form amazon to have a playLast edited by kallipigous; 08-10-2015, 04:18 PM.Comment
I used the gasket off a home gas oven. The fibers are alot tighter, ive attached it with a high heat temp adhesive.Matthew 19:26. With God all things are possible.
My Build: http://www.fornobravo.com/forum/f21/...les-18741.html👍 1Comment
