36" x 18" High. Pompeii with centered chimney. Will this work?
I agree that the forum is difficult to navigate.
I'm now wondering how to connect my 8" round flue to the sheet of stainless that I covered my poured concrete portion of the flue with. As of now, there is no hole cut. I'm waiting for ideas from you pizzaiolos!
That seems too easy. I figured that I was doing something wrong and I was going to have to make a change in plans. I obviously don't do flues often. I will take a look at them and see how they attach. I might get back in touch with more questions if you're available.
Thank youComment
I used these blocks of wood cut to 1/4" longer than a clay brick half. The vermi-crete will help out a lot as a guide as I lay the last dome of red brick. There is 4" of fiber insulation and close to 2" more of vermi-crete. Any one have advice on what to put between the metal and the clay brick? I have left over ceramic fiber insulationI can put a layer of that, or should I spread a layer of vermicrete, or should I let there be air space?
1 PhotoComment
A friend of mine has an oven that was built in a restaurant. It is made out of steel with firebrick on the inside... I think I have a picture of it on my build thread but the concept is the same the flue comes up and angles back to the middle before heading up. He has smoke which comes out the front because the opening is not large enough... not sure how the oven operated indoors... Its looking good though.Last edited by the_dr_masuess; 09-27-2015, 08:42 AM.Loren
My Build - http://www.fornobravo.com/forum/f8/n...ney-19648.html
SLOB - Salt Lake Oven Builders - For WFO builders in Utah - Join here http://www.fornobravo.com/forum/grou...-builders.htmlComment
I'm hoping that my flue is sufficient in size. All metal and concrete that you see in the pictures of my oven will be covered with masonry eventually. Little by little.... I'm 5 rows up on my outer, clay brick dome!A friend of mine has an oven that was built in a restaurant. It is made out of steel with firebrick on the inside... I think I have a picture of it on my build thread but the concept is the same the flue comes up and angles back to the middle before heading up. He has smoke which comes out the front because the opening is not large enough... not sure how the oven operated indoors... Its looking good though.Comment
Nice start on decorative brick work. Are you going to do the twisted chimney too? Reminds me of Tscar's outside the box brick work. Take a look at his final product.Comment
Thank you! I will check out Tscar's stuff! I've been picking away at it and am so close to finishing! A chimney cap, grouting/caulking and some mortar cleanup. I can taste the pizza!!!
I just saw this. I love the complexity of this design, and the use of granite...it's so cool! I did the front chimney but was nervous about an 8" flue, so I went with two 13" square flues. I'm hoping that your 8" will work with the length of travel of the draw.Link to my build
http://www.fornobravo.com/forum/f8/4...nia-19904.html
Link to my pictures
https://plus.google.com/photos/10871...CPfMh4SMmcnQAQComment
