Originally posted by Novaslo
View Post
36" x 18" High. Pompeii with centered chimney. Will this work?
A squirrel tail build will be interesting to watch. Smoke will take the path of least resistance so minimize large angle changes or restrictions. I seem to have read somewhere that 50 sq inches in a round chimney is not the same as 50 sq inches in the rectangular or square chimney in terms of venting efficiency, maybe I was dreaming this but worth checking out. BTW, nice brick and granite work.
Originally posted by UtahBeehiver View PostA squirrel tail build will be interesting to watch. Smoke will take the path of least resistance so minimize large angle changes or restrictions. I seem to have read somewhere that 50 sq inches in a round chimney is not the same as 50 sq inches in the rectangular or square chimney in terms of venting efficiency, maybe I was dreaming this but worth checking out. BTW, nice brick and granite work.
You are right Russell, It was a big discussion on this forum some time back. Square and rectangular flus will still work, but the corners aren't figured into what is called the effective flu area when sizing.
Sizing fireplace openings and flues.Last edited by Gulf; 09-14-2015, 03:59 PM.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
Originally posted by Gulf View PostYou are right Russell, It was a big discussion on this forum some time back. Square and rectangular flus will still work, but the corners aren't figured into what is called the effective flu area when sizing.
That question is probably above my pay grade. But, if I understand you correctly, my honest answer would be no. The sides made of vcrete would need to be much wider and also parged smooth inside imo. I don't think that you want exposed vecrete inside the flue. It will continually shed and fall a little at a time into your landing and possibly on to food. I have seen pics of masonry squirrel tails flues done with brick and with clay tile. If you don't go with metal piping, I think that those materials would be your best bet.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
Originally posted by Gulf View PostThat question is probably above my pay grade. But, if I understand you correctly, my honest answer would be no. The sides made of vcrete would need to be much wider and also parged smooth inside imo. I don't think that you want exposed vecrete inside the flue. It will continually shed and fall a little at a time into your landing and possibly on to food. I have seen pics of masonry squirrel tails flues done with brick and with clay tile. If you don't go with metal piping, I think that those materials would be your best bet.
The inside of the flue is still super hot, and goes through a lot of heat/cool cycling. This may be too late - but I don't think I would trust concrete. I would worry about it cracking and spalling. The flue is going to be 700-800 degrees. I think the stuff you want is called Ciment Fondu. High-temp concrete.
- Likes 2
Originally posted by deejayoh View PostThe inside of the flue is still super hot, and goes through a lot of heat/cool cycling. This may be too late - but I don't think I would trust concrete. I would worry about it cracking and spalling. The flue is going to be 700-800 degrees. I think the stuff you want is called Ciment Fondu. High-temp concrete.
Others might chime in here, maybe it's ok and I am overreacting but I don't think concrete is great with heat/cool over time.
If you line it, it would need to be with stainless - other metals are going to break down from the smoke. A thin layer of mortar doesn't really insulate the concrete so I am not sure that helps.
Is it a real pain to cut out the concrete? If it were me I would just lay it up with firebrick.
- Likes 1
Originally posted by deejayoh View PostOthers might chime in here, maybe it's ok and I am overreacting but I don't think concrete is great with heat/cool over time.
