Good day everybody!
I have been planning and thinking about building a round oven for quite some time now based on the pompeii design from this site (great site to say the least!) and the progress of construction in my head as well as some on paper is taking shape already. I am planning a low dome oven 48" or around that size (depending on minimal brick cutting).
Oven diameter: 48"
Dome Height: 15-16"
Door height: 10 inches semisphere
soldier course: standing on the cooking surface so as to create more airspace for fire: 9"
Door width: 19 inches
Insulation, stand, housing, and vent, I have almost figured out in my head. I have previously built a Hand design oven and it's working just fine and makes good pizza. fire brick wall of 4.5", with cement/lime cladding of 4" with rebar. Insulation of 4" perlite on sides and on top. 6" layer of sea salt under firebrick floor of 4.5" and under that 2 inches of perlite boards. Oven internal dimension is 4' x 5'. Yes, it's big! and I use tons of wood. Fortunately, I use it everyday so I'm not using as much wood as you could imagine with an oven this big. ... a truckload of wood may go for as long as 1 month and 3 weeks if its dry. 1 month and 1 week if its not seasoned. This truck is a six wheeler by the way.
I built this oven for bread. But I mainly use it for pizza since I am only beginning to learn how to bake. And due to the mass, keeping it at pizza temps is quite easy just as long as I manage the fire well and have tons of wood. Once I have a smaller round oven I can use this for bread exclusively and for lower temp cooking such as roasts.
Anyway, with this oven I have gained a bit of understanding of how to build an oven and the principles of the design. A lingering question I have now is with the buttressing of the sides of the oven. My guess (and from what I read in the relevant threads) is that I need to buttress the sides of oven because of its higher tendency to collapse due to the low dome. I can do this with 2 inches of cement cladding with rebar, but that will drastically add to the thermal mass. Another option I have is to pour perlcrete with rebar outside the firebrick walls as a buttressing. Now, from what I see from perlcrete is that after it has dried it will be flaky. I am not sure if it will hold the pressure from the brick wall. I have also read j bek's thread and saw that he used something else for this purpose. That product he used, I do not have access to. Would a mix of 6:1 perlite and cement, 4 inches thick, effectively hold the walls in place? I would deeply appreciate it if anyone has had experience with this and would share some knowledge.
Insulation on top would be blanket and loose perlite. Only the sides will have perlcrete. Under would be board of some kind. I'm pretty sure I will be starting next month so this is getting exciting for me. Would really need some help with any or all of you guys.
-Kulas
Oven diameter: 48"
Dome Height: 15-16"
-Kulas
