39 inch Corner Build
  • Novaslo
    • Dec 2013
    • 279
    #31
    You are doing a fantastic job. You will have a masterpiece to look at with such nice cuts. It takes time. For me, I rushed all the time. Looking back I would take my time, It is hard for me to not run through things and try and do it quickly. But in this case, the build and the time you spend will be a great memory.
    • JRPizza
      • Jan 2012
      • 1557
      #32
      Thanks for the kind words! I looked at your oven pictures - it's beautiful. Does not look rushed at all. I hope mine looks anywhere near as fine when it's done.
      My build thread
      • gastagg
        • May 2013
        • 271
        #33
        Looks great! Inside seams are nice and tight. It's worth the time to get the cuts right. Great job on the arch!
        George
        See my build thread here.
        See my build album here.
        • JRPizza
          • Jan 2012
          • 1557
          #34
          Thanks. The inside of the arch is a little rough and might benefit from being hit with the grinder, but I might just leave it as is depending on how I feel when I get it done.
          My build thread
          • ivancito
            • 155
            #35
            Great looking dome JR. I like your IT tool and how you used it for your inside arch angles. I also just built my IT and was unsure how to set it to proper 42" oven. I noticed your pivot point is right at floor level.
            was that intentional. I have seen other members with the pivot point several inches higher than the cooking floor height and that's where im confused. Any suggestions on clearing this up for me.
            • JRPizza
              • Jan 2012
              • 1557
              #36
              Having the arm pivot point closest to the floors surface and axis of rotation at the centerpoint is the best way to make a perfect hemispherical dome. That is what I was trying to achieve, although I think all of the other variations will produce an oven that works. The forum owners had this picture which puts the axis of rotation at the floor but it is off center, so the dome will be a little wider than twice it's height, unless you make adjustments. Having the tool centered in the middle but above the floor (like with a caster) will make a dome that is taller than half it's radius. I was inspired by both Gulf's build (Mississippi 44") and also by jcg31, where it looked to me like they were going for optimum placement of both axis of rotation and location of pivot point. My pivot point is actually about 1/2 inch above the center of the dome, and at course 5 I did two rotations to shorten my arm by 1/7 of an inch (my threaded rod has pitch of 14 TPI). I'll do the same probably twice more and end up with almost a perfect 19.5 high dome. I really like the symmetry of a 39 inch oven - my door opening is also 19.5. and outer dome is at 48 inches, which fits my sheets of insulation perfectly.
              My build thread
              • Greenman
                • Feb 2013
                • 1123
                #37
                Your build looks good JR. You must be happy with your progress. I used the castor type IT and you can get a true hemisphere by setting it below floor level (I removed a brick and replaced it with a timber block below floor level) and since I used a threaded rod it was simple to shorten it up as the dome progressed to get the desired height. One other point with IT's is that the rod that determines the distance should strike the L shaped piece that engages the brick, in the centre of the brick to keep the brick at 90 degrees to the pivot point. It will make a difference in where the bricks meet with the previous row.
                Cheers ......... Steve
                • JRPizza
                  • Jan 2012
                  • 1557
                  #38
                  Yes, I'm pleased with my progress to date, but I'm hitting one of the parts of the build where things slow down. The cuts are getting more complicated as I near the top of the arch, I had to make a new end for my IT, and access to the dome is getting more difficult. It's funny but when you look at all the build pics they show the dome looking down from the top, so I had this mental image of almost bending over and doing the build. The reality is when the courses get up to and over eye level you have to climb up on the hearth, which can be problematic when working near the edges and makes for lots of climbing up and down. Good exercise I guess. I knew I would eventually need a narrower end for my IT, but thought that would come later. I had trouble with some of my smaller bricks getting access to mortar the edges. The new end gives me plenty of room, but the angle it holds the bricks is slightly different, so I won't begin using it till I start a new course. I went to Mutual Materials Friday and they were out of bricks! Must be lots of folks building ovens . Will pick some more up Monday.
                  My build thread
                  • JRPizza
                    • Jan 2012
                    • 1557
                    #39
                    Last brick of the sixth course in! Can't wait to finish out the arch, and I'm going to have lots of work to do filling gaps. Like UtahBeehiver tells me, "mortar is your friend". I might have to make that part of my signature. Looks like a mortar bag is in my future.
                    My build thread
                    • gastagg
                      • May 2013
                      • 271
                      #40
                      Looking good JR...one of the things that can slow you up once you get to the top is worrying a lot about joints lining up, so I was sizing and cutting each individual brick to avoid this for several courses, and it was going SO SLOW. I was making too big of a deal of it and began cuttings same-size bricks based upon diameter and slope and it started going much faster. After 5 days of curing now, the only crack I have is a hairline NOT in line with those joints that occasionally lined up, but is cracking right through brick and mortar. Keep up the good work.
                      George
                      • JRPizza
                        • Jan 2012
                        • 1557
                        #41
                        Gastagg, you hit the nail (brick) in the head. On my sixth course most of my bricks are a different size. I plan on trying to find a size that will put most of my seams in the middle third of the brick below and pick up a little speed. I was looking at your build and it is very similar to what I hope to end up with - I'm going for an igloo with short brick vent and metal chimney. What product did you end up using for your chimney? Duravent or one of the alternatives?
                        My build thread
                        • JRPizza
                          • Jan 2012
                          • 1557
                          #42
                          I finished mortaring the bricks in my arch today and dropped the form by pulling my shims. The form fell under it's own weight - I was anticipating having to fight to get it out, so was happy how easy it was. The prospect of completing the last course over the top of the arch had me feeling pretty good. I placed a brick in position over my arch TDC brick and used my long level to see how well that brick aligned with the opposite side, and it looked good. Then reality hit - I had the dreaded droop. Gulf and others warned me about it and I was sure I was paying attention, but noooooo I am sort of screwed. My options are doing a teardown (probably not going to happen), slathering on quite a bit of mortar (would be about 3/4 inch thick at the max), or brick at odd angles to make up the gap. The trouble with cutting brick is I need more than 2.5 inches, so would have to either cut some pretty nasty angles (all four sides non-90 degrees), or cut a plug that would be 2.5 inches thick and either fill the backside (outside) with 2" or mortar or stick two bricks together and shave off an inch. I made a paper template (photo 4) showing the shape I need to fill - It's about 4" at the widest, and 3.5 max height. Anybody have a good suggestion? Would a big blob of mortar be better than a brick "sandwich" or a couple of slivers?
                          My build thread
                            • 3884
                            #43
                            I can't really tell from the pics. It may be the droop or the arch is too far forward. Neither is a concern for worry. I wouldn't use an over large mortar joint. It may take a couple or three courses to get it back to a true circle. I wouldn't sweat it. It will be as strong and perform just fine imo.
                            • JRPizza
                              • Jan 2012
                              • 1557
                              #44
                              If the arch was too far forward would the brick sitting on TDC (second pic) be level when held by the IT and contacting the arch on it's forward edge? It seems like it is on the proper plane with all the bricks in that row except those just adjacent with the arch, which is why I think it is droop - and if it is it seems to me that the only option is to get the top of those left and right bricks back on level with either fancy cuts or a bunch of mortar. I can't visualize how going out of round would help me. If I could cut a brick with the profile of the template and position it with my IT, the top of it would be in plane with the bricks on the opposite side and I would be round and level. There does not seem to be any way I can see to drive on without doing a fix now. What am I missing?
                              My build thread
                              • JRPizza
                                • Jan 2012
                                • 1557
                                #45
                                Here is a picture of the inside of my arch from a few rows ago. I think the droop is starting. I'll have to pull out my cardboard tomorrow, fix the angle of my IT relative to the floor like you suggested in post #14, and see what that tells me.
                                My build thread
