Yes, got the pipe, adapter, and cap from Menards - they were on sale at the time so it was the best price. I think I got the adapter from Amazon - Dektite #8 Red Silicone Metal Roof Pipe Flashing. I thought I was being smart by putting the hole between two of the high ridges in the roofing but did end up creating a dam. Too late by the time I noticed so will watch it and if it corrodes I'll reskin the roof and adjust the panels so it can drain better. Here is a picture so you can see what not to do...1 Photo
Hi JR
Thanks for documenting your build so well. I will be borrowing heavily from your experience as I'm planning a 42" corner build. I plan on having a roof built over the oven that will be an uninsulated sort of portico with a low sloping metal roof. I'm curious how you flashed the chimney without creating a dam on the roof when it rains. Did I read correctly that you bought your chimney pipe and fittings from Menards?
Thanks again
Steve
That is out of my area of expertise, so I'm probably not the best one to answer. That said if your sub-soil is compacted and you use plenty of rebar in the slab you are probably good, at least until the big one hits.
Maybe one of the concrete guys on the forum will weigh in.
JR, do you think 6” slab with 2-3” gravel would be good enough for the ground foundation?
In answer to your questions,
1. Yes, pretty much. Dimensions can be read from my post #3 of this thread in the first thumbnail pic. My back walls of my stand used 4 full length CMU's (cinder blocks) @~15 5/8 plus a half block @~7 5/8, where the short sides were 3 full CMU's long. See pic below
2. I was shooting for a 4" slab but just measured and I guess I hit about 3 7/8 of concrete sitting on 1/2" hardibacker.
3. No other support but the CMU's. I put a liberal grid of rebar tied into the rebar in the stand and made sure it was located in the center of the slab. It sure seems to support the weight of the oven (no cracking or sagging) and I am very glad I left the underside open as much as possible. Didn't really use the space much the first year or so as it gets wet there in the winter, but I made a raised platform using pallets and am surprised at how much wood I can pack under there. I hear folks say they wouldn't want to crawl under the hearth to fetch wood but other than bumping my head a few times and maybe fighting a few spiders I don't have a problem accessing the furthest reaches.1 Photo
Great build JR. I have couple of questions when you have an opportunity.
1. What were the final dimensions of your hearth slab? Were they ~72 for outer and ~48 on inner parts?
2. How thick is the hearth slab, 5 inch?
3. Can you please confirm that there are no other support below the hearth slab except outer cinder blocks? If yes, have you seen any issues?. I would like to have to have access to the whole section at the bottom but seen number of corner builds having additional blocks under the slab.
Jr, I want to build the 39" as we spoke about. You have convinced me its the perfect size. I have spent time on this thread and tried to draw it out, but it doesnt seem to add up. If you have some time to spare, can you put a concise dimensions of hearth, oven? I know I am asking for a lot but a concise picture plan will really help me visualize and replicate. If its too much work, please dont worry!Originally posted by JRPizza View PostNot per se. If you decide to build a 39" you should be able to mine most dimensions from this thread or the one linked below. Anything else you need let me know and I can probably pull them from my models
https://community.fornobravo.com/for...18-hearth-size
Totally stuck on hearth size, and forum problems are keeping me from looking at some images that I think might help me. I have laid out a 70X70 corner base, but space is at a premium so would like to shorten to a 62.5X62.5. I have a sketch but am not sure about how much room the vent/landing need. I am
Hey JR! Its me again, do you have any plans in a concise manner? Like Simple to understand the dimensions? I am not too good with this CAD stuff, I tried, but out of my reachOriginally posted by JRPizza View PostI've been working on my oven for a little while and have been debating starting a build thread, as I probably won't have much to add in terms of artistry or inventiveness over the excellent work already posted on this forum. That said, I thought I would share what I have done and hopefully continue to get support from the great folks that have been helping me so far and others that might chime in. I have used CAD for my initial layouts that some may find interesting.
I'll start with some pictures to show progress to date. First picture is the patio where the oven will be located. My Wife and I stained it ourselves and were pretty happy with the way it came out. Note we had supports sunk in the concrete for the uprights needed for the shelter we wanted to build. We weren't totally sure how big a structure we wanted or how the oven might look so I made a layout using Freecad.
Sorry to keep bothering you friend
Sure thing mdbronco , file attached below. Had to zip it as the forum software does not recognize the cad files. Have you used Freecad before? It is what I use and what the format the files are saved in. Let me know and I might be able to export in another format (maybe). Also let me know if you have any questions after you open and check it out.Attached Files
- Likes 1
Old thread JR but if you get this, any chance on sharing some of your CAD files for the 39" corner? This looks bang-on what I'm trying to do...
