Thanks you everyone for your help and previous threads. The forum is a truly wonderful resource. I am an Irish man living in Luxembourg, so this will be the Lux build.
So, I guess I have gotten to the stage where I (think I) am ready to pour the concrete for the foundation. I figured I may as well start a build thread...
I have dug the foundation (about 19cm or 20cm) , and laid the gravel (8cm). I have cut the forms, and cut the steel, and laid it all in place. At this stage I think all I have to do is lay the plastic, tie the steel up, and level the forms...
The foundation is 150cm (59") square back edges, 90cm (35.5")sides, and 84.5cm( 33.25") front angle, on a corner build. Ideally I would like a 36 inch igloo build, but in truth that will be a bit tight, so it will reduce a bit. Rebar is 12mm (0.5") at 27cm (10.6") distance
Before I take the next step of moving on to the pour, any veterans have any pointers for me? Pics attached.
Thanks and wish me luck!
Eoin
Eoin
