Clay flue
  • jmargush
    • Jun 2013
    • 46
    Clay flue
    If I decide to use a clay flue instead of stainless steel, can I just run the clay flue up through the roof of my oven house and put a cap or top on top of it,?
    or do I need to build an enclosure (Chimney) around the flue?
  • DavidApp
    • Sep 2012
    • 348
    I am no expert on chimneys but I can say that the entry to my SS chimney gets up to 600 degreed+ so I would think that the clay flue would get very hot. Go with an enclosed chimney. Adds to support as well.
    David
    • Tscarborough
      • Oct 2009
      • 3341
      Code is 1" airspace with 4" masonry wrap around terracotta flues.
      • jmargush
        • Jun 2013
        • 46
        So is masonry wrap the same thing as the ceramic blanket insulation or something different?
        And I assume you wrap the flue with the insulation wrap then 1" of airspace?
