Elizabeth's oven
  • Faz
    • Jul 2007
    • 56
    #16
    Re: Elizabeth's oven
    I am planning a similar L shape design, with a BBQ to one side and a bench to the other, like Mahootna. My CAD version is even earlier though, as although the plans are well developed they are stored in my brain only and haven't quite made it to paper so far!
    Anyway, on a more serious note, I think it would be better for the bench to be slightly lower than the oven to prevent rain falling on the bench from then working its way into the structure of the oven and causing dampness, especially over the winter months. I was planning on casting a level concrete pad for all 3 sections but the oven would be raised up slightly due to the insulating pad and some exterior finish (probably reclaimed brick).
    • egalecki
      • Mar 2008
      • 1049
      #17
      Well, I'm ready to form up, I think. I have to get the ok from my husband, the contractor, but if it isn't right I'm not digging anymore. I've dug modified footers to spread the load under the block, and that, with the rebar and wire, should be ok.
      I need to run it by DH, but I think I'm just going to have 4 courses of block, which should put the top of my hearth at about 36 inches. The 4" of insulating block plus the firebrick will put me at about 42" finished, and if I make countertop to the side of the dome and stucco to it, the finished counter will be about the same height as the ones inside the house. I shouldn't get rain water into the oven at all. I just don't know how much room on the hearth I'll have to make counter, so I can't plan that until I get there.
      Here are some pictures
      Elizabeth
      • egalecki
        • Mar 2008
        • 1049
        #18
        I got the forms done today. Lots of measuring over and over to make sure I was square and the areas were actually the right size!
        My concrete is going to be a lot deeper than really necessary- an average of about 7 inches, but I am assured that it will be fine. The slope of the yard made it hard to estimate how much dirt to take out.
        I still have to put the steel in and go around the edge of the forms tamping in some dirt in a few places but as soon as I can swing the 1 1/2 yards in the concrete truck (and face having to wheelbarrow it over from the alley ) I'll get it poured and ready for block.
        Elizabeth
        • RTflorida
          • Jan 2007
          • 1446
          #19
          Elizabeth, I'm with ya on the Auto PAd 2.0.....To me half the fun and intrigue of a project comes from graph paper, ruler, legal pad, and several sharp pencils (I still don't use mechanical pencils and have the identical type of pencil sharpener we had in our elementary school classrooms).
          I really like the "L" with the corner bump for the oven, can't wait to see the progression from paper to 3D fuctionality. Keep the photos coming.
          RT
          • Xabia Jim
            • Dec 2006
            • 1168
            #20
            Originally posted by RTflorida
            I really like the "L" with the corner bump for the oven, ... Keep the photos coming.
            RT
            ditto, good luck with the build
            • egalecki
              • Mar 2008
              • 1049
              #21
              Monsoon season seems to be over for now, so I'm going to pour the foundation on Monday, I think. My dh has come up with a plan for the block which uses fewer of them- combining them with lintels we already have left over from building something else. He is insisting on putting in rebar sticking out of the slab, though, to tie them in, so now I have to figure out placement. I'll take a picture of the autopad drawing of it after I do some measuring and then post it.
              It's going so slowly-too many things, good and bad, keep getting in the way of my wonderful project. On the other hand, I haven't been dreaming about it or waking up from trying to calculate in my sleep.
              I found a woodfired pizza restaurant over in Blacksburg- a friend says the owner apparently built it himself. I'll try to get pictures sometime- The owners are from Abruzzo, and the pizza is pretty good, but so is everything else they have! (PEI mussels with linguine, oh my...)
              Elizabeth
              • gjbingham
                • Sep 2007
                • 2021
                #22
                Oh yah! Cozze! If they have a pasta vongole, give it a try too. Lots of EVOO and herbs, huh?
                GJBingham
                • egalecki
                  • Mar 2008
                  • 1049
                  #23
                  They have a red clam sauce, but it's really hard here to get the little tiny clams in the shells for vongole.
                  The cozze had lots of herbs, EVOO, a little white wine, and just enough garlic to make it good. Happy food dance. (what my kids call it when I wiggle in my chair in delight over a really good dish)
                  Apparently my DH has ordered concrete for this afternoon, so I'm off to get rebar and wire in place. Wish me luck with the leveling and smoothing! (should be ok, we used a laser level to set the forms, but you never know)
                  Elizabeth
                  • egalecki
                    • Mar 2008
                    • 1049
                    #24
                    Whew! We have concrete foundation! My lovely husband wheeled it from the truck in the alley, I shoved it around with the rake and screeded (?) it and then he brushed it and I did the edge thingy and made a couple of fracture points between the WFO part and the counter side and the BBQ side. I'm going to have to use some mortar under the first course of block to be absolutely sure I am starting level, I expect, but it looks pretty good!
                    Elizabeth
                    • egalecki
                      • Mar 2008
                      • 1049
                      #25
                      some more pictures
                      I made stepping stones out of leftover concrete using a box of cove molding with duct tape- I don't know how they'll turn out, but it was better than wasting it!
                      Elizabeth
                      • gjbingham
                        • Sep 2007
                        • 2021
                        #26
                        Nice concrete work!
                        I posted my recipe for mussels a couple of weeks ago, but its hidden in another thread. A search for mussels should find it pretty easily. I highly recommend you try it.
                        Keep up the good work!
                        GJBingham
                        • egalecki
                          • Mar 2008
                          • 1049
                          #27
                          Playing with the block layout- I had two 64" precast lintels along with all of these block in the home of leftover building supplies- DH has suggested building a corner and two walls, as laid out, and then putting the lintels across the long sides at the top. I'll have to trim the funny end off the corner blocks and cut the end off one lintel to make it fit, but I think it'll work. I'll also have to trim up the edges that come to the cut off corner. I think all the trimming can be hidden on the inside, although the final product shouldn't show anyway once I cover it up with, well, something. I don't know what yet for sure.
                          I'm going to be a few blocks short, but I refuse to dig around in that barn anymore. I am sure there are big hairy spiders in there and I don't want to meet them. I wore gloves and long sleeves this morning digging around and still felt like they were crawling all over me. Alas, they're my only real fear.
                          Still, all in all, finding as many essentially free (after all, I think DH paid for them over 10 years ago, so that has to count as free for this project!) blocks as I did will help a bit with cost. So far he hasn't blinked at anything's cost, even the concrete, but I think he's looking forward to pizza, bread and other fine foods...
                          Elizabeth
                          • Ken524
                            • May 2007
                            • 1655
                            #28
                            Elizabeth,
                            Looks like you all have a great start. I like the stepping stones. I made some with our leftover concrete also; but yours look much nicer. I made simple squares.
                            Ken H. - Kentucky
                            42" Pompeii
                            • egalecki
                              • Mar 2008
                              • 1049
                              #29
                              Originally posted by Ken524
                              Elizabeth,
                              I saw yours and stole your idea, with my own twist. I don't know how these will work yet, they aren't as flat as I thought they'd be. But it felt better than wasting the concrete...
                              Elizabeth
                              • egalecki
                                • Mar 2008
                                • 1049
                                #30
                                So, now I'm shorter than I was... after lugging all those blocks around all morning, I think I've compressed a few inches I could ill afford to lose
                                Due to the odd nature of the leftovers I decided to use, my blocks don't all fit as tight as some of yours seem to, but they're very stable, don't rock, and most importantly, they're level. We put rebar in every other hole and filled ALL the holes with concrete. Since we don't have a regular stand going it took fewer than 10 bags of concrete. I did have to use mortar to level the first course with itself and each other, but it worked out ok-the mortar mostly took care of the stupid edge I'd put on- looked really good but not practical under the block edges. Note to anyone else- don't do a nice "sidewalk" edge under the places you are putting block!
                                We had to cut one end of one of the lintels- wow those things are hard to break, even when scored all the way around with a saw. The rebar inside really wants to keep them together.
                                Tomorrow we're going to fool around with the decking for the hearth- we're using metal decking like you pour porches on- it should be plenty strong enough and we won't have to mess with a form for the bottom. I doubt we get the hearth poured tomorrow (gotta go see the vet at the barn about breeding a mare, of course it's right in the middle of my day!) but maybe on Thursday if it doesn't monsoon. We haven't been getting regular rain- it either is dry or we get an inch overnight. Even so, it's much better than last year, when we got NOTHING for months.
                                I'm going to have some work to do on the edges at the front of the oven- I am not sure how to make them pretty. I had a hard time cutting the block at an angle there. Maybe a form and some concrete? Maybe just glue on some wonder board and stucco over it?
                                Elizabeth
