Can I reduce a 36" internal diameter to a 27" design?
  • Superk
    • Dec 2015
    • 2
    hi all,
    It appears I've built my stand and hearth a bit small (before i found FB). I've got a 1200mm square base (47inch). My question is
    - can I continue with the Pompei design and just reduce the cooking space from 36" to 27"? or would i be better off looking for other ways to save space (ie reduce insulation thickness etc)?
    Does anyone know if any good ideas? any comments would be very welcome
    Chris
    • 9211
    Better not to skimp on insulation. My oven is only 21" internal diam. How big is the oven in your kitchen? If you want to cook a whole pig you need a large oven, but even those folk with big ovens tend to only cook one pizza at a time because it will cook them faster than you can prep them. I can easily cook for a crowd of 50 for pizzas and my oven will do the family roast ok. We usually cook a turkey for Christmas, but because of the lower door height I can only fit in a 5 kg turkey. Frequently cook bread, but only a couple of loaves at a time, how much bread can a family eat before it's stale?
    Remember that the ovens fuel consumption is roughly directly proportional to its volume, (roughly because an 8 litre V8 won't actually use 8 times the fuel of a one litre four cylinder),so the smaller oven uses way less fuel meaning you don't think twice about firing it up to only cook three pizzas or a couple of loaves of bread.
    A 42" oven has double the diameter of a 21", but 8 times the volume.
    A smaller oven also requires a smaller, lighter and cheaper stand to support it. There is also far less time required for the build.
    • Spoon
      • Jan 2016
      • 37
      Hi David, I'm also thinking of building a smaller oven, maybe 21"-24" in size. What size opening would you recommend on these smaller ovens?
        • 5261
        A rule of thumb for the oven opening height is 62-65% of the internal dome ceiling height. IE if the oven ceiling height is 12" then the opening height is 12 X .65 =7.8 " using 65%. width is user choice within reason and dome diameter constraints.
