PizzaJNKY pompeii build
  • PizzaJNKY
    • Mar 2008
    • 159
    #16
    Re: PizzaJNKY pompeii build
    Ouch. I was afraid of that. Looks like I will be busy repairing on Saturday, instead of continuing with the build. Thanks for the reply, I think it would have been worse to continue, then find out that I should have repaired it early on.
    "Pizza, the world's most perfect food."
    • james
      Brick Oven Merchant
      • Mar 2005
      • 4648
      #17
      Hey George,
      I think we might have actually helped somebody today. Way to go. :-)
      PizzaJNKY, the re-do won't take much time and is probably worth it. We're driving north Saturday; we'll wave as we drive by,
      • PizzaJNKY
        • Mar 2008
        • 159
        #18
        Here is a quick update on my struggles. I built the first arch, pulled the form too soon, then the whole thing tumbled. Built it a second time, waited a day, and it worked, but it just didn't look quite right, so I broke it down. It appears my weekend is booked, but I may get a second chance at it on Sunday.
        I think part of my problem has been that I am in such a rush to finish. I think I am going to start taking my time, slow it down a little. Less mistakes, higher quality.....I hope.
        • mfiore
          • Oct 2007
          • 919
          #19
          We'd love to see some photos on the forum.
          Mike - Saginaw, MI
          Picasa Web Album
          My oven build thread
          • gjbingham
            • Sep 2007
            • 2021
            #20
            PizzaJNKY,
            I was just killing time while my daughter was biting my ankles the other day. I was paging through a masonry book. It recommended a week of cure before pulling arch forms. That was for the upper half of a brick "moon window" - basically a full brick circle. If the you don't fit those arch bricks tight and use a keystone, I'd give it a full week.
            GJBingham
            • PizzaJNKY
              • Mar 2008
              • 159
              #21
              Thanks for the info Bingham. Mfiore, I will try to download Picasa sometime this week, so that you guys can see my progress since Yahoo is not working.
              Last edited by PizzaJNKY; 04-23-2008, 07:48 AM. Reason: Sorry Mfiore, I spelled your name wrong.
              • PizzaJNKY
                • Mar 2008
                • 159
                #22
                Hello again. I actually got some work done today and even set up a picasa photo page so that I can paste them here at FB. Unfortunately, I can't figure out how to paste the photos from Picasa to this site. I guess I will keep trying, so that everyone can see my mess. I think once all the newbies see my oven, they will think to themselves, "Heck, if he can do it, I can do it!"
                • PizzaJNKY
                  • Mar 2008
                  • 159
                  #23
                  I've started the 8th rank today. The top of my oven looks like its going to be around 18-1/2 inches high (Interior height) so the bricks appear to be straight up and down at this point. I'm using 2x4's to hold them in place as I move on the next. So far I've only set 3 8th rank bricks. (I had to take a quick break-it feels like its 100 degrees outside right now. I've started my vacation, so If I can do one rank per day from here on out, I should set the keystone on Thursday! That is if I don't run out of bricks or mortar. I pray I don't run out of mortar, my wife just found out how much I've spent on this project already, and she'd have a cow If I have to buy more.
                  • PizzaJNKY
                    • Mar 2008
                    • 159
                    #24
                    8th rank was not as easy as I thought it would be. I would set one brick, move on to the next, and my 2x4 would bump into the other 2x4 knocking down 2 other bricks. One step forward, two steps backward. I finally had enough, deciding to quit with only 4 bricks left to finish the 8th rank.
                    I think I may have to develop a form of some sort before I continue. Since I am already at 17" high, I thought of maybe just cutting a sheet of plywood and stretching across the opening at the top, and laying the remaining courses ontop of the wood to keep them from falling. Or even better, maybe I can find an excersise ball big enough to use as a form. All I know is that I need something in there.
                    • thebadger
                      • Jun 2007
                      • 383
                      #25
                      PizzaJNKY
                      I'm having the same trouble on my upper rows. I was concerend the excerise ball would give too much so I build a platformand intend to fill with sand. Feel free to check on my pics if you like.
                      Good luck.
                      Dick
                      thebadger
                      • RTflorida
                        • Jan 2007
                        • 1446
                        #26
                        JNKY, just curious what type of mortar you are using. Many who have used Refmix (Refrax) have stated its fast setting - hold the brick in place for 20-30 seconds and your on to the next. Personally, I used Heatstop 50, with the same results - hold it, it sets, on to the next.....I went so far as to make a pretty elaborate curved form out of 1/4" plywood standing on edge with about a dozen "fins" glued together in the center...my plan was to knock it apart when done; as it turned out, the Heatstop set quick and I cut each brick to fit so I never used the form (until the curing fires).
                        RT
                        • gjbingham
                          • Sep 2007
                          • 2021
                          #27
                          Guys! Try mixing a little less water with your mortar. It should not slip off the slide of a trowel when it is held sideways/vertical. That is the wettest you want it. You should be able to place a brick at the 8th course, hold it for 30 sec. to a minute, and it should stay put. I alternated sides as I got higher. Place one brick, hold it till it stays, go to the opposite side, place a brick there. Then back to the first spot. That previous brick is less likely to move at that point. Obstinent bricks that insisted on sliding, I used a small stick with a shim.
                          Have faith!
                          GJBingham
                          • Dutchoven
                            • Apr 2007
                            • 931
                            #28
                            Good advice from George...brickies tend to slap their loaded trowel or the mortar onto their mortar board to eliminate excess water when they have touchy bricks to lay...the mortar will stick to an upside down trowel that way
                            Dutch
                            • RTflorida
                              • Jan 2007
                              • 1446
                              #29
                              Spot on advice George. As I have always been told - use the dryest mix possible for maximum strength, whether mortar, grout, concrete. That said, it still must be workable and give you ample working time; I guess there is a fine line between sticky and slippery.....I always start with a peanut butter consistency then add a little more or less water depending on application and conditions. Mix small batches until you are comfortable with the working time and workability.
                              I always cringe when guys break out the mortar paddles and their drills and mix a wheelbarrow load or a full 5 gal bucket; unless you are laying concrete block or are a professional mason laying brick, you don't need that much mortar at one time and are probably making it too soupy to extend the working time. Just my 2 cents......
                              RT
                              • PizzaJNKY
                                • Mar 2008
                                • 159
                                #30
                                Thanks again for the advice. I have been making small batches, but probably too much water. I'll try less water tomorrow. I bought a huge ball this evening, just in case. I also like badgers idea, just not sure how the heck I would remove all the sand once I was done with it. I can't wait for tomorrow...The saga continues...
