Originally posted by sharptailhunter
View Post
Yep, perfect sense. I have actually been measuring to the wrong side of the brick when cutting, so my bricks have been a little oversized for a while. Still not too bad on the grout joints until the 10th chain. Boom, it was obvious i had to cut the bricks down. The steeper you go, seems like it is a little harder to keep them level. I will try and use my IT as long as I can, but I may have to remodel it again. Thanks for the response.
